Need Clarification on st205 rear sub frame on ST185
Postby Humble1 » Fri Jan 04, 2013 3:19 am
I do know the rear sub frame and differential bolt to st185 with no modification.
My question is, will all my stock st185 Arms, driveshaft, ect, mount up to st205 sub frame or do i have to use arms, hubs, ect. from st205?
Humble1
Re: Need Clarification on st205 rear sub frame on ST185
Postby Tecker185 » Fri Jan 04, 2013 4:02 am
Everything will bolt to the st205 subframe. I've got a st205 subframe in my car.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby Humble1 » Fri Jan 04, 2013 6:51 am
Thank You, Sir
Humble1
Postby phattyduck » Fri Jan 04, 2013 4:57 pm
If you use the ST205 arms, you can add 30mm/1.2" to each side in track. Fills out the wheel wells nicely and then you don't need to use spacers to make wheels look good. It adds a bunch of camber though, so you have to take care of that...
But... all the ST185 parts bolt directly to the ST205 subframe (the subframe itself is actually the same part number and the Torsen diff is the same as the optional ST185 part).
PS. I even have all ST205 rear parts on my Camry Alltrac... and yes, it all just bolts in.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby 801Alltrac » Fri Jan 11, 2013 12:21 am
Could it work on 165?
801Alltrac
Images: 13
Postby phattyduck » Fri Jan 11, 2013 12:28 am
801Alltrac wrote:Could it work on 165?
Same deal as the ST185.
Edit, to expand on my statement above, the rear subframe is the same part number for the ST165, ST185, ST205 and SV25 (Camry Alltrac), thus all the parts that attach to it are also compatible.
phattyduck
Postby 801Alltrac » Fri Jan 11, 2013 12:38 am
:D Awesome I figured as much , now off to find parts :shoots:
801Alltrac
Images: 13
Postby aus jd 2703 » Wed Sep 25, 2013 10:22 pm
curiosity question how different are 205 hubs? have been looking for 205 arms and hubs as I have been told the hubs fix the camber issue?
my plan would be to buy 205 hubs arms and cv's and convert to 5x114 while im pulling the rear out. but use the 185 torsen and subframe.
aus jd 2703
Postby alltracman78 » Thu Sep 26, 2013 6:37 pm
The hub has nothing to do with the camber. It simply holds the wheel and rotates in the wheel bearing. It also has a slightly larger centric than the 185 [so the 185 rotors won't fit without shaving a tiny bit].
The knuckle/spindle is the same. But the brake dust shield is larger to fit the larger 205 rotor.
AFAIK the "camber issue" is because the top of the strut isn't pushed out like the knuckle is by the longer arms.
But you can adjust a small amount of camber with the stock bolts, and if you want more either round out the holes in the strut, buy camber plates for the strut mount or buy crash bolts.
Postby Tecker185 » Thu Sep 26, 2013 7:46 pm
To fix the camber issue you have to run st205 struts. That's what I'm running in my car now. Pretty much works out to not need spacers. I've got a complete st205 subframe, arms, diff, knuckles, brakes and struts on my car now all bolt on.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby CMS-GT4 » Thu Sep 26, 2013 8:28 pm
Interesting to learn that the 205 struts are different. That is useful for sorting out the camber.
Postby aus jd 2703 » Thu Sep 26, 2013 9:01 pm
im very curious to see proof the struts are different as I know for a fact the upper mounts are the same distance apart, so it has to be different in the hubs or in the struts which I feel is highly unlikely.
aus jd 2703
Postby phattyduck » Fri Sep 27, 2013 4:05 pm
Hubs and knuckles are the same as far as geometry. The tabs on the strut that bolt to the knuckle are different on the ST205 compared to the 165/185 - they are a different angle.
I just needed to use two camber bolts to get back around 1* on both sides for my Alltrac. The longer ST205 arms add about 30mm to each side. Oh, and make sure you use the longer ST205 rear axles too. :)
Another fun side effect is that the Whiteline swaybar clears the brake line brackets on Tein SS coilovers...
phattyduck
