ST215 Clutch Problems
Postby 3spowerhouse » Sun Mar 03, 2013 5:28 pm
My ST185 has a 4th gen ST215 swap, the motor came with the original manual box and had the clutch changed to an exedy stock replacement, after a few short drives the clutch would smell really bad until eventually it stopped working entirely, it was later discovered the brakes were binding up(which could have contributed to the clutch burning), so that was fixed and I then replaced the clutch with an ACT disc and Exedy pressure plate, but now i'm smelling the clutch burning yet again. What can be causing this issue? is there a difference in clutches with the 4th gen that I should know about? a different flywheel perhaps?
3spowerhouse
Re: ST215 Clutch Problems
Postby GT4_DRED » Sun Mar 03, 2013 6:45 pm
Are you putting a clutch assembly for a st185 in it or is this something custom that both manufacturers did for you?
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby 3spowerhouse » Sun Mar 03, 2013 7:06 pm
Both disc and pressure plate are st185 items, the flywheel is st215, upon brief inspection it appears to be the same as any other 3sgte flywheel, not sure if I'm missing anything.
3spowerhouse
Postby lumbercis » Mon Mar 04, 2013 6:47 pm
Possibly bad installation or something in the trans was damaged when you got it.
I'm running an Exedy twin plate for an ST185 in my ST215 manual with no noticeable problems. The trans itself is still an E150f although a later revision.
Caldina powered...
lumbercis
Postby 3spowerhouse » Mon Mar 04, 2013 7:42 pm
I was the one who did the job this time around, I''m certain it isn't an installation issue. I was able to confirm that the part #'"s on the st215 flywheel and all other 3sgte flywheels are the same so that rules that out as a possible problem.
3spowerhouse
Postby lumbercis » Tue Mar 05, 2013 12:12 am
Was your pedal free play adjusted? Did you use an OEM throwout bearing? You sure it's a good idea to mix and match a disk/pressure plate from different manufacturers? It sounds like the clutch isn't engaging/disengaging fully. And if it's not installation it has to be a parts issue.
Caldina powered...
lumbercis
Postby 3spowerhouse » Tue Mar 05, 2013 1:48 am
Was your pedal free play adjusted?- nope but I think I'll take a look at that asap, i believe it may have been tampered with.
Did you use an OEM throwout bearing?- yes, new OEM realeasing bearing
-As far as mix and matching with the clutch and pressure plate I don't think it should cause the problem I've been having they"re all built to work on the same platform. I've see it done all the time without hiccup.
Thanks for all the input! Much valued
3spowerhouse
Postby phattyduck » Tue Mar 05, 2013 5:16 pm
I can't remember... is the 3s-gte flywheel stepped? Has it been machined? maybe the friction surface has the wrong offset to the pressure plate mounting surface.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby 3spowerhouse » Tue Mar 05, 2013 5:59 pm
I didn't have the flywheel machined but if i do end up having to take the gearbox off again i'll definitely have it done this time around.
3spowerhouse
