transmission identification
Postby brutekiller787 » Sat Mar 23, 2013 4:38 am
Can you identify an alltrac transmission in anyway by the outside. I got a trans for 100 but i dont know what one it is. It has cooler lines and what i think is an electric speedo. Just debating whether its worth swapping on
brutekiller787
Re: transmission identification
Postby Corey » Sat Mar 23, 2013 2:09 pm
Electronic speedo means its a JDM transmission. Does it have the Viscous couping selector lever on the right side of the transfer case? If not, then its an ST205 E154F transmission - recommended swap because of improved syncros.
If it does, then it could be a JDM E150F (standard GT-Four ST185 tranny) or a JDM E151F (RC tranny)
Corey
Images: 50
Postby brutekiller787 » Sat Mar 23, 2013 3:37 pm
it does have the selector lever. is there any other external markings or anything that could help me identify it? also, never seen an electronic speedo. is it a three wire plug in the shape of a triangle, bolted to the back top of the trans very close to the shifter cable brackets?
brutekiller787
Postby Corey » Sat Mar 23, 2013 3:56 pm
I don't think there are any part numbers or external markings which can be used to identify the transmissions. Maybe someone else knows.
This may help
http://gtfour.supras.org.nz/gearboxpics.htm
That's right. It can be unbolted and removed from the transmission and replaced with the USDM mechanical speedo if desired.
Corey
Images: 50
Postby underscore » Sat Mar 23, 2013 4:30 pm
Maybe post pictures of it?
Postby brutekiller787 » Sat Mar 23, 2013 6:30 pm
hmmm. according to that website i now think i have a regular jdm st185 trans. it looks to be a cast steel shift fork which again, according to the website, says regular one.
brutekiller787
Postby 88gt4DE » Sat Mar 23, 2013 8:50 pm
Any vin plate on it anywhere ?
Postby brutekiller787 » Sat Mar 23, 2013 8:59 pm
where would that be? could you provide a picture to reference where it would be? it's pretty dirty
brutekiller787
Postby 88gt4DE » Sat Mar 23, 2013 9:46 pm
I cannot verify this on 185's and others but on my 165 its here ....
Look to the right of where the axle bolts on ...
Postby alltracman78 » Mon Mar 25, 2013 11:17 am
brutekiller787 wrote:it does have the selector lever. is there any other external markings or anything that could help me identify it? also, never seen an electronic speedo. is it a three wire plug in the shape of a triangle, bolted to the back top of the trans very close to the shifter cable brackets?
Triangle usually means mechanical speedo. The electronic speedos have an oval plug.
Both kinds send an electronic signal, so both have plugs.
If you have a VIN plate it's a US trans [probably, since you have a mechanical speedo].
Users browsing this forum: Baidu [Spider] and 2 guests
