1988 trans? problem
1988 trans? problem
Postby llc3guys » Tue Jun 18, 2013 9:56 pm
1988 toyota all trac sr5. Went a few feet in 1st gear and heard rattling. Stopped, restarted, and tried again - same thing but backed up fine with no noise. Then, after another restart, it wouldn't move, at all (including reverse), and now makes a clunking sound whem I try put in gear and apply gas. Still starts fine. Any ideas will greatly be appreciated.
llc3guys
Re: 1988 trans? problem
Postby 88gt4DE » Tue Jun 18, 2013 10:35 pm
So it doesn't go into gear at all now ?
Postby llc3guys » Wed Jun 19, 2013 3:11 pm
Thank you very much for your reply. Yes, it goes into gear but it will not move with clutch out and, if revved-up a little, makes a clunking sound. Also, it was not a gradual thing as in a clutch wearing out. It was running fine, as usual, turned it off for about 10 minutes, problem began within 30 seconds of restarting.
llc3guys
Postby 88gt4DE » Wed Jun 19, 2013 9:32 pm
Sounds like you either broke an axle or something in trans ...
Postby llc3guys » Thu Jun 27, 2013 11:13 pm
You nailed it, - broken axles! Hope this helps others to isolate what seems to be a transmission problem, but isn't. Thanks.
llc3guys
Postby 88gt4DE » Fri Jun 28, 2013 11:50 pm
Man you lucked out there :smokes:
