ST165 propellor shaft carrier bearings
Postby JohnNK » Sat Aug 03, 2013 1:04 am
I need to replace the two drive shaft carrier bearings on my 1988 ST165. How difficult will this be? It is hard to tell from the BGB. I have done strut replacement and similar work.
I have a good source for this type of part if someone is interested.
Re: ST165 propellor shaft carrier bearings
Postby alltracman78 » Sat Aug 03, 2013 9:42 am
Unbolt the driveshaft section, unstake and unbolt the flange nut, press off flange, press off bearing.
Reverse for installation.
It might be cheaper to just get a steel 1 piece driveshaft made.
Postby exiled82 » Sat Nov 02, 2013 5:54 am
Hey mate
I need a set of the carrier bearings for my st165
You mentioned you have a supplier?
How much to ship a set to Melbourne Australia?
