Rear Diff Ring Gear Size?
Postby alltracman78 » Thu Aug 08, 2013 9:34 pm
Anyone know what it is?
The diameter of the ring gear in the rear diff.
I don't care about ratios, just the diameter.
Trying to figure if the TORSEN will fit into another diff.
Re: Rear Diff Ring Gear Size?
Postby spitfiremk16 » Thu Aug 08, 2013 11:15 pm
Are you trying to see if an alltrac diff will fit in your cressida? I can take apart the diff you sold me a while ago and check ring gear diameter for you. Its out of the car at the moment anyways and i dont plan on putting a stock diff back in the car when the subframe goes back up anyways.
spitfiremk16
Postby alltracman78 » Thu Aug 08, 2013 11:42 pm
If you don't mind.
One of the pinion bearings is bad in the Cressida and I'm not sure if it did any damage to the diff.
Just trying to pre plan.
Postby alltracman78 » Sat Aug 17, 2013 12:19 am
No one has any clue?
