Odd sound when turning = axle bind? Help!
Postby underscore » Sat Sep 21, 2013 4:47 pm
I'm getting a really nasty sound when turning, especially when I turn left. It's a heavy, repetitive clunk/knock coming from the wheel area, at low speeds it only happens at full lock but at higher speeds (more suspension compression) it'll happen when the wheels aren't anywhere near full lock. From what I gather this could be one of three things:
1) Axle bind
2) The WRX rotors rubbing
3) Tires rubbing
I can't find any decent videos online to compare to the sound I'm hearing so I can't say for sure it's axle bind, the rotors do have a small rub mark on the backside but when I check the clearance they seem to have a lot of room with the suspension compressed and the wheel turned, and the tires did rub the frame a touch before I added spacers, but I would think that both of those would make a more constant noise, not a clunk-clunk-clunk.
Picture of the axle at nearly full lock with the suspension compressed:
Not the best picture but it shows how low I am in the front (hiding in the top right) (I don't think I'm very low?)
If this is the axles binding, what can I do to fix it?
Re: Odd sound when turning = axle bind? Help!
Postby Meurz » Sat Sep 21, 2013 7:32 pm
Symptoms sound like a broken CV joint..
Turbocelica.nl
Meurz
Postby underscore » Sun Sep 22, 2013 2:11 am
I thought a broken one made more of a ticking and would do it all the time? Any idea why it was fine until I lowered the car?
Postby celicadude93 » Sun Oct 27, 2013 5:49 pm
also sounds like a worn cv joint to me. clunking knocking type noise when turning is usually the first symptom. on my tiburon g put it off for a while and got to the point it sounded like a rod knock when accelerating lol. my advise. auto zone axles are cheap with lifetime warranty lol
1990 celica alltrac (restored)
2005 toyota 4runner
1990 celica alltrac (daily driver, trusty rusty)
celicadude93
Images: 13
Postby 187flatliner » Sun Oct 27, 2013 7:12 pm
best to just pull it off and check out that axle....wouldnt take long but be on the look out to replace it right away if you do this.
GOT PROBLEMS WITH MY FWD
187flatliner
Postby warracer » Sun Oct 27, 2013 7:13 pm
your axles are done :doh:
Same happened to me, full lock clicking and after 2-3 months , started doing it all the time
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby underscore » Mon Oct 28, 2013 2:50 am
I'm actually glad to hear it's the axle, sine I have a replacement on the way.
Postby MWP » Mon Oct 28, 2013 4:42 am
Its not an axle, its a CV joint.
CV joints can be replaced without changing the whole axle.
Its actually a better idea to do it this way, as a lot of the replacement axles are not as strong as the original Toyota items.
Postby underscore » Mon Oct 28, 2013 4:48 am
Tomato tomahtoe. Either way it's pooched, and the new one is a rebuilt axle but it cost me less than buying the rebuild kits would.
Postby Awesome-Trac » Wed Jan 08, 2014 7:36 pm
sorry to bring up the old thread but im having the same problem now Except i changed pretty much everything you can think of! I recently replaced the Axle with a brand new GSP one, Replaced the wheel bearing and seal, replaced the inner and outer tie-rod end and wheel hub. It sounds like a horrible scraping plus a side of Wobbling But when i lifted the car to check everything is on tight and i mean ZERO movement also i changed the brake pads which i also thought was the problem so is there anything else that i could be missing?
•Daniel
Awesome-Trac
Postby underscore » Thu Jan 09, 2014 12:13 am
I forgot to update this, the new axle didn't fix my problem. I upped the stiffness on the coilovers and it got better/harder to cause and my mechanic friend says it sounds like tire rub. Which would make sense since my wheel offset is way too high for the car.
Postby Awesome-Trac » Thu Jan 09, 2014 12:43 am
underscore wrote:I forgot to update this, the new axle didn't fix my problem. I upped the stiffness on the coilovers and it got better/harder to cause and my mechanic friend says it sounds like tire rub. Which would make sense since my wheel offset is way too high for the car.
hey i was wondering if you ever heard of the strut tower bearing? cause apparently that might be our problem
•Daniel
Awesome-Trac
Postby underscore » Fri Jan 10, 2014 12:49 am
Strut tower bearing? Is that the same as the strut top hat ie the piece bolted between the damper and the chassis at the top end?
Postby Awesome-Trac » Fri Jan 10, 2014 1:44 am
I guess you can call it that, I'm about to change mine an ill keep you posted
•Daniel
Awesome-Trac
Postby underscore » Fri Jan 10, 2014 1:56 am
Yeah let me know, I hope that isn't my problem as I have brand new coilovers.
