Does anyone in So Cal have any 185 rear axles
Postby Bryon » Fri Nov 01, 2013 9:12 pm
If so Get at me. Or any suggestions on new ones besides toyota
Bryon
Re: Does anyone in So Cal have any 185 rear axles
Postby tubasteve » Sat Nov 02, 2013 6:10 pm
ill check tonight. im using this to remind me
tubasteve
Postby Paykoo » Sat Nov 02, 2013 7:03 pm
i just broke one aswell and searched for a week look up this part number on google 60-5085
good luck
Paykoo
Postby Bryon » Sat Nov 02, 2013 8:12 pm
Thanx for the info. I wouldnt think Summit would have those axles. Did you install yours yet? I keep hearing bad things about the reman axles, but hell if I can afford 574. a piece from Toyota.
Bryon
Postby tubasteve » Sat Nov 02, 2013 8:46 pm
Sweet, that's an Orielly number(my second job)
tubasteve
Rear remanded rears shouldn't be too bad.unlike fronts
tubasteve
Postby Paykoo » Sat Nov 02, 2013 9:11 pm
no i havent installed yet i ordered it last night cuz i found it it should be just as good as anything else i man for 80 bux really cant complain if your making good power you should just look into some aftermarket axles
but for riding around stock these should be mor than sufficient
Paykoo
Postby Bryon » Sun Nov 03, 2013 12:15 am
Well thanx for the tips. This a bit off topic but you guys should come out to Glen Helen in Dec for Rally cross. $60. gets you 6 runs around a dirt rally x course. good times! check it out on Calclubrallyx.com I will be out there with my dirty 165 hooptie.
Bryon
Postby Rick89GTS » Sun Nov 03, 2013 2:22 am
Paykoo wrote:no i havent installed yet i ordered it last night cuz i found it it should be just as good as anything else i man for 80 bux really cant complain if your making good power you should just look into some aftermarket axles
Did O'Reilly's have one in stock? #60-5085 is the rear axle - did they have to special order it?
Rick89GTS
Postby tubasteve » Sun Nov 03, 2013 3:29 am
It's technically sop. It's an exchange...actually it's yours rebuilt 60, plus 40 for shipping
tubasteve
Postby tubasteve » Sun Nov 03, 2013 3:31 am
tubasteve
Postby tubasteve » Sun Nov 03, 2013 3:32 am
That's pretty decent considering. I'm bummed I threw out my four axles and cut up my 165s
tubasteve
Postby Rick89GTS » Sun Nov 03, 2013 4:10 am
^Thanks for the info. 165 and 185 same parts numbers.
Rick89GTS
Postby tubasteve » Sun Nov 03, 2013 4:40 am
That is correct
tubasteve
Postby Paykoo » Sun Nov 03, 2013 11:10 am
i ordered online since all the stores was either sop or rebuild mine
Paykoo
