frankinstien transmission E350
Postby BlackKnight » Thu Dec 05, 2013 12:59 am
I need help and my friend said there is a lot of experience here so I reaching out. I do not have a Celica but do have a Toyota Scion tC with a 5-speed manual. Heres my dilemma I am making 519whp and 488wtq but the transmission is not holding up. I am looking to do something similar that a friend of mine did unless someone can recommend a shop that can custom cut me a gear. The 4th gear in this transmission is weak and breaks under severe load. I have cryo and rem treated the entire transmission and had it correctly shimmed to ensure it has the correct tolerances however it still breaks due to being weak. Is there any gear that I can have shaved down that would be stronger to run than the oem one.
For instance my friends E350 transmission has the following:
1st oem
2nd Corolla XRS
3rd oem
4th Corolla XRS
5th MR2
FD MR2
Looking for useful input. I really don't want to use a different transmission or have adapters made at this point due to the clutch, limited slip diff, and axles being used costing 3600 bucks. I would rather not make these obsolete but if it comes down to it, I will.
BlackKnight
Re: frankinstien transmission E350
Postby GT4_DRED » Thu Dec 05, 2013 3:54 pm
BlackKnight wrote:I need help and my friend said there is a lot of experience here so I reaching out. I do not have a Celica but do have a Toyota Scion tC with a 5-speed manual. Heres my dilemma I am making 519whp and 488wtq but the transmission is not holding up. I am looking to do something similar that a friend of mine did unless someone can recommend a shop that can custom cut me a gear. The 4th gear in this transmission is weak and breaks under severe load. I have cryo and rem treated the entire transmission and had it correctly shimmed to ensure it has the correct tolerances however it still breaks due to being weak. Is there any gear that I can have shaved down that would be stronger to run than the oem one.
1st oem
2nd Corolla XRS
3rd oem
4th Corolla XRS
5th MR2
FD MR2
Is it possible to use the 4th gear from the MR2 turbo, the entire gearset or the entire box itself?
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby Chuck.hudson » Thu Dec 05, 2013 4:04 pm
Man I know you came here for information which I have none for you but I sure would like to see what a 500 hp scion looks like
Chuck.hudson
Postby BlackKnight » Thu Dec 05, 2013 4:05 pm
Gears yes after shaving them down.
BlackKnight
Postby BlackKnight » Thu Dec 05, 2013 4:07 pm
Pics
BlackKnight
Postby BlackKnight » Thu Dec 05, 2013 4:08 pm
Pics 2
BlackKnight
Postby CMS-GT4 » Thu Dec 05, 2013 4:14 pm
I would say look into using a mr2 transmission completely. It will add some weight, but I could had sworn it was discussed that it bolts up in some manner to the TC engine. You might want to look for the XB that has an awd gtfour transmission. I am pretty sure its using the TC engine. There is a link posted in this forum somewhere.
Postby phattyduck » Thu Dec 05, 2013 5:14 pm
Yeah, I've seen enough pictures of MR2's with the front end of the ground running stock(ish) gearboxes to figure that they can take the abuse. An E153 should bolt up to the 2az in the tC. Not sure of the clutch situation, but something custom should be pretty easy to make. If the track width is right, '88-'91 Camry V6 axles (complete) should be able to be used with a custom axle carrier behind the block. Maybe even the E350 (stock tC manual trans?) axles might work... I don't know. Oh, and good clutch-type diffs are available for the E153 for traction.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby Chuck.hudson » Thu Dec 05, 2013 7:16 pm
man those headers look cool as hell do you have twin wastegates?
Chuck.hudson
Postby BlackKnight » Thu Dec 05, 2013 11:45 pm
Heres a run down of my setup:
Brian Crower
-Stroker Kit
-Stage II FI Cams
-.5mm oversized valves nitrate coated
-spring and retainer kit
CP 89mm bore Teflon coated skirts, ceramic coated dome 8.8:1 CR pistons
GT3582R turbo
Twin scroll manifold with twin wastegates
3" full exhaust
Swirl pot fuel system
Liquid to air intercooler
Cryo and Rem treated transmission
O.S Giken LSD
Driveshaftshop 3.9 stage axles (600HP) rated already broke one
Exedy twin disc clutch
1000cc FIC injectors
Greddy Emanage Ultimate with boost sensor
Now I do not know many transmission codes or years which these were used. If someone could tell me what year MR2 transmission and transmission code to search for. Also what Corolla XRS transmission code and year to look for? Thank you.
BlackKnight
Postby phattyduck » Fri Dec 06, 2013 11:04 pm
The wikipedia page has some information as a start:
http://en.wikipedia.org/wiki/Toyota_E_transmission
MR2 Turbo E153 - '90+ (note the reversed shift lever location, can be converted)
Camry V6 E153 - '97-'99 (FWD setup)
In the past, I even had an E154F (ST205 AWD gearbox) converted to FWD with a KAAZ LSD and some MR2 E153 parts (the gearing I wanted and the FWD selector setup and an otherwise 'free' transmission that came with a clip). So a broken MR2 trans + a GT4/Alltrac gearbox is another option if you can do the frankenstein work.
After looking at some pics of the E350, it looks like the 'narrow gear' version of the E-series box with a small differential. There are a number of other transmissions in that category ('88-'91 Camry V6, 1st gen Rav4, etc.) Its hard to say how much custom work it will be to get it all working, but it might be blazing a new trail for the tC guys...
phattyduck
Postby crxgames » Sun Dec 08, 2013 12:28 am
CMS-GT4 wrote:I would say look into using a mr2 transmission completely. It will add some weight, but I could had sworn it was discussed that it bolts up in some manner to the TC engine. You might want to look for the XB that has an awd gtfour transmission. I am pretty sure its using the TC engine. There is a link posted in this forum somewhere.
Where should i look for this xB post? xB is my daily and that intrigues me.
crxgames
Postby BlackKnight » Sun Dec 08, 2013 12:46 am
XB uses very similar transmission as the tC so it will have the same issues.
BlackKnight
Postby BlackKnight » Tue Jan 07, 2014 11:46 pm
I'm going to actually start disassembley this weekend. I haven't had time due to schedule and having to move. I found a place to custom build me gears.
BlackKnight
Postby CMS-GT4 » Wed Jan 08, 2014 7:23 pm
I have looked for the post for a while, and I do not know where it went. I know I posted it in a thread where a member was talking about using a v6 or something.
Users browsing this forum: Baidu [Spider] and 2 guests
