frankinstien transmission E350
Re: frankinstien transmission E350
Postby BlackKnight » Wed Feb 05, 2014 2:47 pm
Also what gear oil is everyone running in these transmissions?
BlackKnight
Postby phattyduck » Wed Feb 05, 2014 4:39 pm
Alltrac/GT4s have to run a GL5 rated fluid due to the hypoid gears (severely limiting choices). You can run any GL4 or GL5 fluid since you are running the trans as a 2WD unit. Get whatever you like - the trans is essentially bulletproof... unless it is in an MR2 lifting the front end off the ground, at which point it start breaking the splines in the diff. Alltrac guys break the transfer case or center differential which you don't have.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby BlackKnight » Thu Feb 06, 2014 12:23 am
Obviously you can tell the difference in the gearsets no wonder it's stronger. Btw we are modifying the differential pump relief valve and making it higher pressure.
BlackKnight
Postby BlackKnight » Thu Feb 06, 2014 12:56 am
How much power can the OEM LSD handle? bolting up the transmission is definitely going to be fun, its not exactly a direct bolt on. The front side mount will work and the top transmission mount will work, the rear mount is definitely will have to be fabbed. Clutch is fine, passenger axle is fine, the driver axle will be frankinstiened. lol. As progress continues I will update. The shift linkage will be custom. I am taking mine from my E-350 modifying it to fit the E153 and will be on the right side of the transmission as I need. I have to drill one hole in it for a bracket and cut a grove for the external c clip. I will post pictures later.
BlackKnight
Postby phattyduck » Thu Feb 06, 2014 5:50 pm
Do you have MR2 axle stubs? At least, the inner for driver's side? Go get an Alltrac front outer axle (or an '88-'91 V6 Camry axle) and see if the splines fit your hubs - they should (5x100 hubs). You can also just get a complete (from the junkyard) Camry V6 (auto or manual trans, doesn't matter) axle for test fitting and the inner stub. Then you just need a spacer between the inner and outer section to get the length correct. Probably only 1/2", as the Camry of that generation has a 1.2" and the Celica Alltrac is 1" narrower track width than the Scion.
Nothing custom beside the spacer, which isn't a wear item anyway...
phattyduck
Postby BlackKnight » Thu Feb 06, 2014 6:33 pm
I know a place to buy cheap new axles, I'm removing the tripod and using the shell only with my dss axles. The driver inner tripod splines are longer than my tCs. The passenger axle is perfect. Since I have DSS axles the outer splines and hubs are different, larger bore.
BlackKnight
Postby BlackKnight » Sat Feb 08, 2014 11:58 pm
Test fitment. Two mounts bolt perfect, one has to be made. I'm taking shift linkage to a machine shop to modify so it will fit this transmission on the right side. Need to manufacture shift linkage bracket. Need to get both axle stubs.
BlackKnight
Postby BlackKnight » Sat Feb 15, 2014 8:11 pm
[attachment=-1]uploadfromtaptalk1392498685240.jpg[/attachment]
Rear mount done.
BlackKnight
Postby BlackKnight » Mon Feb 17, 2014 11:56 pm
[attachment=-1]uploadfromtaptalk1392684936501.jpg[/attachment]
Two holes on the right I had to drill and tap, part of shifter assembly conversion.
BlackKnight
Postby BlackKnight » Tue Feb 25, 2014 11:37 am
Need more information please. I can search for a E153 transmission and can find the different cars that came with it. The issue I'm having is finding the correct axles. I have a E153 from a 94 Toyota MR2 turbo LSD, Right hand drive. Would a rhd actually make a difference on the axles? Pic to follow
BlackKnight
Postby BlackKnight » Tue Feb 25, 2014 11:41 am
[attachment=-1]uploadfromtaptalk1393332029147.jpg[/attachment]
The longer stub is the passenger side however on my differential I need it on the driver side. So the axles are reversed.
BlackKnight
Postby phattyduck » Tue Feb 25, 2014 5:29 pm
RHD vs. LHD makes no difference for axles. The drivetrain is always in the same orientation compared to the car. Just the driver's controls swap sides (steering and pedals).
The left and right axles are different where they go into the differential - obviously the long stub axle goes behind the motor and the short stub goes on the other side.
phattyduck
Postby BlackKnight » Tue Feb 25, 2014 7:00 pm
That's what I was thinking but no one can cross reference the dealer part numbers.
BlackKnight
Postby phattyduck » Wed Feb 26, 2014 5:14 pm
BlackKnight wrote:That's what I was thinking but no one can cross reference the dealer part numbers.
http://www.toyodiy.com - make an account to see the pictures, do it yourself.
phattyduck
Postby BlackKnight » Wed Feb 26, 2014 11:29 pm
Im registered on the website, I'll login again and try to look. I may have found my answer. I hope so at least. Its a Autozone Duralast axle new, I'm only using the tripod. 07 Toyota Camry V-6 Manual. The passenger axle seems it will work great. I won't know until the new gears I ordered today come in and are installed.
BlackKnight
