Short shifter applications
Postby Gordon12 » Tue Jan 07, 2014 8:08 am
So guys I was thinking, if there's anyone out there that know, it would be nice to put together a list of true legitimate short shifters, the years they fit, the years they can fit, and cars they can fit. For example if one for a st165 fits a st162, or even if it fits other Gens. Doing this for others and myself. I have done a lot of searching and there really isn't much info on it. As far as I've found, they don't make them for the 162, but there are some that fit. And IM sure there are others that would like to know.
Gordon12
Re: Short shifter applications
Postby jsd » Tue Jan 07, 2014 8:22 pm
AndyTTR wrote:ST202 shift lever fits into the ST162 shift mechanism for a cheap short-shifter upgrade.
Found in this thread: http://www.toymods.org.au/forums/tech-c ... tio-4.html
It's actually a very interesting thread and has a bunch more stuff on gt4's
jsd
Postby Gordon12 » Tue Jan 07, 2014 8:29 pm
Nice. Thanks. Just found that short shifters from 165's fit 162's as well.
Gordon12
Postby Eurus » Wed Jan 08, 2014 6:06 am
I have a short shifter from here http://www.twmperformance.com/shortshifters/toyotashortshifters/toyotacelicashortshifters.htm in my Lancer, and I love it; even my girl is going to get one for her SR swap, after driving my car.
Eurus
Postby d0yougetme » Wed Jan 08, 2014 10:11 pm
Very interested...how much more effort does the short shifter (st165 )require?
d0yougetme
Postby Gordon12 » Wed Jan 08, 2014 11:41 pm
d0yougetme wrote:Very interested...how much more effort does the short shifter (st165 )require?
I actually don't know. Just been told it fits. But with a weighted shift knob and maybe an extension probably be fine.
Gordon12
Postby phattyduck » Thu Jan 09, 2014 5:02 pm
Most of the mid-80's through late 90's Toyota FWD (or FWD-based) cars have compatible shifters. I use an ST205 shifter on my '89 Camry... and used an ST18x TWM short shifter on my '90 Camry many years back.
The only challenge is finding the right mixture of length, throw, etc. for your car.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby Gordon12 » Thu Jan 09, 2014 8:27 pm
Well guys we need some more confirmed applications. As far as this shifter from this car will "for sure" fit in this other car. Because eventually I'd like to make a post containing just the cars and applications for future use and anyone else. That way this topic will "almost" not have to be brought up again.
Gordon12
Postby CMS-GT4 » Thu Jan 09, 2014 8:33 pm
I use an AE92 short shifter in my st185.
Postby Gordon12 » Thu Jan 09, 2014 8:38 pm
CMS-GT4 wrote:I use an AE92 short shifter in my st185.
And it just threw right in?
Gordon12
Postby CMS-GT4 » Thu Jan 09, 2014 8:47 pm
Yep. Just replaced the shifter rod, and greased it was all. I have had it in both 185 housings.
Postby Gordon12 » Thu Jan 09, 2014 10:15 pm
CMS-GT4 wrote:Yep. Just replaced the shifter rod, and greased it was all. I have had it in both 185 housings.
No cutting mods. Did it really make your throw shorter? Or just hand movement shorter?
Gordon12
Gordon12
Postby CMS-GT4 » Fri Jan 10, 2014 12:59 am
It didn't need cutting to work, but I did shorten the upper arm. The lower section is much longer, reducing the shift, but the top wasn't much shorter than stock so I had that cut and rewelded.
Postby Gordon12 » Fri Jan 10, 2014 1:19 am
CMS-GT4 wrote:It didn't need cutting to work, but I did shorten the upper arm. The lower section is much longer, reducing the shift, but the top wasn't much shorter than stock so I had that cut and rewelded.
Awesome thanks. well that's one more to add to the list.
Gordon12
