tranny axle heat shield
Postby psipwrd » Mon Feb 17, 2014 4:58 am
I suppose these will protect my CV boots from heat and premature rot/failure. Does anyone know where/how they bolt up?
psipwrd
Re: tranny axle heat shield
Postby alltracman78 » Mon Feb 17, 2014 5:15 pm
On the transmission right above where the axle is.
IIRC the R side is larger [bolts to end of transfer case].
Postby phattyduck » Mon Feb 17, 2014 5:27 pm
The one on the top bolts on to the transfer case under the power steering pump. The picture is in pretty much the right orientation as if you were looking in front he wheel well how it bolts up.
I don't recognize the other one.
In my opinion, they are more to keep axle grease from getting up everywhere in the engine bay when the boots fail. At least, that's what they have done for me. :D
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby psipwrd » Mon Feb 17, 2014 8:13 pm
Thanks for the quick replies. Phattyduck, I found the bottom bracket in a google search so with your input, I think i'm on the right track for both. Thx again!
psipwrd
