St165 front driver axle?
Postby oka » Mon Apr 07, 2014 2:26 am
Hi. What other toyota axles fits my st165??i heared the v6 camry is the same. Can somebody tell me what year and what the part numbers for the v6 camry?? Thanks
st165..04 ls430 vip
oka
Re: St165 front driver axle?
Postby phattyduck » Mon Apr 07, 2014 8:33 pm
Assuming the ST165 uses the 2-piece axles with the 6 allen bolts to hold the inner and outer section together...
'88-'91 Camry V6 axles fit. They are the same for the manual and automatic transmission for that car.
It should look like this:
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby oka » Tue Apr 08, 2014 2:24 am
phattyduck wrote:Assuming the ST165 uses the 2-piece axles with the 6 allen bolts to hold the inner and outer section together...
Thanks charlie i appreciate it
st165..04 ls430 vip
oka
Users browsing this forum: athousandleaves and 1 guest
