Drive shaft not in, or diff bearing failure? Pictures...
Postby lordvampire » Mon Apr 28, 2014 3:00 pm
Hi,
Need help, can anyone tell if the driveshaft is its place? I have PDF Manual, but there does not read that out. Basically driveshaft is not solid. I wounder if it not in place or gearbox/differential bearing is out. Its gearbox side /Left driveshaft.
If it is in its palce, Is it possible to change the diffential bearing Engine/Gearbox on the car? :)
lordvampire
Re: Drive shaft not in, or diff bearing failure? Pictures...
Postby celica_gtx » Mon Apr 28, 2014 4:15 pm
yes thats how its suppose to be.
and idk what your truly asking here.
are you have some binding/clunking noise while turning?
are you not getting power out of it..
also its a cv half shaft/transaxle.
http://www.celicatech.com/bgbonline/90alltrac/SA/SA.htm
everything ull need to know can be found here. idk where ur looking.
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby lordvampire » Mon Apr 28, 2014 4:33 pm
Thanks for reply. If shaft is in its place, then differential bearing is worn out. It moves around in its nest. It makes noise while in driving too yes. Is it possible to change bearing when gearbox/engine is in the car? (I feel its a stupid question :)
lordvampire
Postby celica_gtx » Mon Apr 28, 2014 6:32 pm
I'd start looking into the cv take it out n inspect it and the out put shaft hub.if it only makes noise while Turing a certain direction its the cv for sure.
celica_gtx
Postby lordvampire » Mon Apr 28, 2014 7:14 pm
I´ll make video tomorrow :D
lordvampire
Postby lordvampire » Tue Apr 29, 2014 5:56 am
I tryed other driveshaft... same.. Problem is in the gearbox. There has to be some bearing... is it changeable engine/gearbox on the car?
lordvampire
Postby lordvampire » Tue Apr 29, 2014 3:55 pm
Video, shaky :D , but better than nothing... http://youtu.be/CsZ0JMZP7Ng
lordvampire
Postby celica_gtx » Tue Apr 29, 2014 5:16 pm
damn! id just pull em off and peak inside..
celica_gtx
Postby lordvampire » Mon May 05, 2014 5:59 pm
Ok, new carlos gearbox is in, problem solved :)... beak down the old gearbox maybe later. Thanks for reply´s.
lordvampire
Postby celica_gtx » Mon May 05, 2014 8:38 pm
Yea I would like to see ur problem
celica_gtx
