St204 shifter into st185
Postby Mr Alltrac » Fri Jul 25, 2014 4:15 pm
Is this just a basic swap over? Just switch out the shifter itself?
I saw the info on the main alltrac. Net front page, but doesn't mention what you need to swap? Anyone have any ideas
Mr Alltrac
Re: St204 shifter into st185
Postby CMS-GT4 » Fri Jul 25, 2014 4:53 pm
You have to push the shift rod out of the housing and then put it in your old housing. I think the 7th gen 5speed works the same way. I used a short shift rod for a ae92. I just had to go get a stack of thick washers for spacer. Make sure you grease it when you put it back in.
Postby MWP » Fri Aug 08, 2014 3:09 pm
CMS-GT4 wrote:You have to push the shift rod out of the housing and then put it in your old housing.
If you do that, you only get a shorter front-back motion.
Side to side remains the same length as your not changing out the side arm.
I did this mounting a 205 shifter in my 185.
It feels *awesome*.
Massive improvement over the sloppy long 185 shifter.
Postby Mr Alltrac » Mon Aug 11, 2014 9:53 pm
How tall is your bracket that holds the shifter?
Mr Alltrac
Postby CMS-GT4 » Mon Aug 11, 2014 10:27 pm
Can the side arm be removed? I might go grab one from a junk yard off a 7th gen.
Postby MWP » Fri Aug 15, 2014 2:48 am
Mr Alltrac wrote:How tall is your bracket that holds the shifter?
Not very, maybe 15mm.
I raised it that extra bit for shifter knob position rather than having to do it to make it fit.
Postby rallygarage » Fri Aug 15, 2014 12:12 pm
That is an ST205 shifter in the last picture?
rallygarage
Postby MWP » Fri Aug 22, 2014 3:41 pm
In my photo above?
Yes.... well a very chopped up one anyway.
