Clutch slave piston travel?
Postby MWP » Sat Jul 26, 2014 6:13 am
Can someone do me a favor and measure how much piston travel you have at the clutch save when the pedal is fully depressed.
I just bled ~500ml of fluid through the system, but the clutch pedal still seems very soft.
I get 13mm of travel at the slave piston.
The engine isnt running yet, so i cant test if the clutch is actually being disengaged.
Thanks in advance :D
Re: Clutch slave piston travel?
Postby FC Zach » Sat Jul 26, 2014 7:21 am
I measured about a cm of travel.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby MWP » Sat Jul 26, 2014 1:10 pm
Ok, thanks.
Maybe this new pressure plate just isnt as heavy as the old one.
Guess ill just have to wait and see.
Postby FC Zach » Sat Jul 26, 2014 1:17 pm
What pressure plate do you have?
FC Zach
Images: 9
Postby MWP » Sat Jul 26, 2014 4:32 pm
DSBMS Clutch Kit from these guys: http://www.xtremeclutch.com.au/
I should have the 1050kg pressure plate, but ill double check that.
I do remember they did something extra with it to reduce the air-gap (or something like that) to make it more streetable.
