Rear diff flange/oil seal
Postby TCalltrac90 » Sun Sep 20, 2015 10:44 pm
My rear diff is leaking slightly from the pinion flange. I was curious If I can just replace the oil seal or if I need to replace other parts as well like the front bearing and spacer. Any help would be great, thanks.
TCalltrac90
Re: Rear diff flange/oil seal
Postby alltracman78 » Mon Sep 21, 2015 1:18 am
Technically you're supposed to change the spacer [it's a crush sleeve] if you remove the nut.
But if you know what you're doing you don't have to.
If you re tighten the nut too much or too little you at best will damage the pinion bearings and at worst ruin the whole diff, so be careful.
Postby 88gt4DE » Fri Oct 02, 2015 11:47 pm
I had this issue also after putting in a new rear pinion seal and replaced the nut .. blah blah ... I took it back off and at the recommendation of a guy in my shop that worked on these cars when they were under warranty ... Clean everything up and put some of the orange toyota sealer on the spines of the pinion flange and put it back together. Walla ... all fixed ... 8)
Postby TCalltrac90 » Sat Oct 03, 2015 2:37 am
88gt4DE wrote:I had this issue also after putting in a new rear pinion seal and replaced the nut .. blah blah ... I took it back off and at the recommendation of a guy in my shop that works on these cars when they were under warranty ... Clean everything up and put some of the orange toyota sealer on the spines of the pinion flange and put it back together. Walla ... all fixed ... 8)
The fipg stuff? Which is like Toyota liquid gasket?
TCalltrac90
Postby 88gt4DE » Sat Oct 10, 2015 2:24 am
Yes , the Orange stuff , not black ....
