Abs ring
Abs ring
Postby Mr Alltrac » Mon Sep 28, 2015 1:09 pm
Is it possible to remove the abs ring and put it on a axle that didn't have abs.
I bought an axle a few years ago without oNE and would like to get everything working again.
Mr Alltrac
Re: Abs ring
Postby zaluss » Mon Sep 28, 2015 2:59 pm
Mr Alltrac wrote:Is it possible to remove the abs ring and put it on a axle that didn't have abs.
IIRC the ABS ring is on the hub, not the axle. The splines should be the same.
zaluss
Re: Abs ring
Postby Mr Alltrac » Mon Sep 28, 2015 3:06 pm
viewtopic.php?t=50613
Very first pic. You can see the abs ring. It looks like a hub puller could grab it, not 100% sure tho.
Mr Alltrac
Re: Abs ring
Postby zaluss » Mon Sep 28, 2015 3:29 pm
Mr Alltrac wrote:http://www.alltrac.net/phpBB2/viewtopic.php?t=50613
Is this for your Alltrac? There should be splines on either side for the front axles.
I'm not sure on the MR2 setup.
zaluss
Re: Abs ring
Postby Mr Alltrac » Mon Sep 28, 2015 3:43 pm
Yes it's for an st185, my front axles are relatively setup like that. I'm not wanting the whole axle, just wondering if I could replace just the ring. Little gear looking thing at the end of the axle.
Mr Alltrac
Re: Abs ring
Postby yyonline » Tue Sep 29, 2015 12:23 am
For ST185 you can do this, but it's tricky. I used a new ABS ring as I wasn't able to remove one without bending it.
http://www.amazon.com/Dorman-917-537-AB ... B009PJJK80
That kit also includes the dust shields that go on either side of the ABS ring.
yyonline
Re: Abs ring
Postby Mr Alltrac » Tue Sep 29, 2015 1:41 am
Awesome, just what I was looking for. Thank you.
Mr Alltrac
