KAAZ Front/Center LSD combo. SERIOUS FEELER!!!
Re: KAAZ Front/Center LSD combo. SERIOUS FEELER!!!
Postby eric thompson » Sat Mar 19, 2016 3:13 pm
Vicious how? What's it doing?
ST165-PARTS-RED
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Postby kevzep » Sat Mar 19, 2016 3:39 pm
eric thompson wrote:Vicious how? What's it doing?
Sounds like its doing its job to me.
Front/Centre LSD may not suit some people for road use, as they do wear your tyres out, and will scuff and bind a bit, at normal driving speeds, I feel there's no real benefit...
When I had a ST205 as a road car, I found the standard system works absolutely fine, and I wouldn't actually want a front/centre LSD.
However if you are using it on track or especially rally, it is essential for maximum traction for maximum drive train efficiency and car balance.....
I hope Kaaz do actually put it into production.....I thought this was dead in the water, but perhaps not...
ST185 Narrow body Rally Car
ST205 engine transmission
Stocked with lots of go fast goodies....
400+bhp depending on boost.
kevzep
Postby hazee » Sat Mar 19, 2016 4:15 pm
As said above scuffing , locking and binding at slow corner speed
Steering has a totally different feel - much heavier . Can see me being a lot more tired after racing
Feels like it's going to be great on track... My st205 is not road legal , so will know more next Friday
I already know I wouldn't have it on a road car though
hazee
Postby RedCelicaTRD » Sun Mar 20, 2016 4:28 am
Are you running any friction modifier or just straight gear oil?
Postby TTEETT » Sun Mar 20, 2016 6:26 am
+1 for buying the LDS kit. Fingers crossed.
TTEETT
Postby hazee » Sun Mar 20, 2016 11:02 am
I'm running the correct kaaz oil .
Which is mineral based with friction modifier
And actually the gear change better than when I had fully synthetic race oil
hazee
Postby RedCelicaTRD » Tue Mar 22, 2016 1:30 pm
Since the diffs are a clutch type you should be able to change the lockup percentage. Did you leave the front diff at 100% lockup?
Postby hazee » Tue Mar 22, 2016 3:02 pm
Yea I got a rebuild kit from kaaz , and advanced Motorsport engineering , fitted and shimmed it all --- I would not have a clue how to do it.
They would have loaded them a 100%
I've just put a cusco Rs type diff in the back of a mk3 supra that loaded 100% and that locking pretty hard too.
They both just need bedding in abit
My rear cusco diff on the 4 feels the same as standard - but it was second hand so plates will be worn
hazee
Postby RedCelicaTRD » Tue Mar 22, 2016 3:12 pm
That's good to hear. The binding can be tuned out by changing the clutch configuration.
Postby kevzep » Tue Mar 22, 2016 7:27 pm
underscore wrote:
eric thompson wrote:I can only assume that the difference will be what a rear lsd is to an open read diff. One wheel drive, only the inside wheel spinning during inclement weather, much more predidictable and precise handling... Not to mention eliminating the power sapping center viscous coupling for a clutch type unit that transfers power rearward with more immediacy. Both of which also actually do something productive under deceleration as well.... I guess the best perspective would be a DSM eclipse owner who has upgraded their units to LSD's. Since stock GSX's were also open front and viscous center..... No pressure though.
I know how they work and what differences they're supposed to make, I'm just trying to find out what quantity of difference will be made on our cars. I want to be sure that it's something that makes a significant, noticeable difference and isn't just something that shaves 0.2s off a lap time.
Well, for example on my rally car the difference between the Viscous and a locked centre was very very significant.
In a very familiar hillclimb road we use, which is fairly short. My best time was 2min 1 sec. Same tyres same road conditions, the locked Centre gave me a best time of 1min 53 sec.
There is a significant increase in traction.
This is on a gravel road of course, but it will translate to better than just a couple of 10ths on a circuit....
kevzep
Postby underscore » Tue Mar 22, 2016 9:20 pm
Good to hear some real world results, thanks for the update!
Postby kevzep » Tue Mar 22, 2016 9:53 pm
underscore wrote:Good to hear some real world results, thanks for the update!
Of course this is a locked centre, but does give you come idea of the improvement in traction....
kevzep
Postby AwdGte » Sun Mar 27, 2016 8:56 pm
How much are the Evo units?
AwdGte
Postby hazee » Mon Mar 28, 2016 7:24 pm
Well I have to admit it ...... The kaaz front did feels great on track.
I'm using the expensive kaaz oil and the gear changes feel smoother than before
The next day even after the bedding in process it was a lot easier to use - then on track it reduced understeer and increased grip.
Took it easy on the practice as the engine had been out so just wanted to get everything up to racing temps to check for leaks and issues.
Also lots of oil oil on track
https://youtu.be/awAmGIg0h4U
hazee
Postby abraxxa » Mon Mar 28, 2016 8:13 pm
Thanks for taking us on a tour around Brands Hatch!
Really great weather too!
facelift ST205
abraxxa
