KAAZ Front/Center LSD combo. SERIOUS FEELER!!!
Re: KAAZ Front/Center LSD combo. SERIOUS FEELER!!!
Postby underscore » Sun Dec 13, 2015 11:07 pm
DeeCee wrote:Tuning Developments is a reputable company in the UK.
Well that's good, in which case I'd suggest contacting them directly through their usual channels since (and I know I'm being paranoid) we can't guarantee "Mike" actually works for them.
Postby MWP » Mon Dec 14, 2015 7:23 am
DeeCee wrote:At the end of the day, 3 choices are on the table: KAAZ, Quaife or BNZ's rally specialists - when it rains, it pours?
No, at the end of today we still have 0 options :(
It'll be pouring when all three options are on the shelf ready to sell & ship.
Postby kevzep » Tue Dec 15, 2015 12:06 am
Yeah, at this point, I would have to agree with this, and until they are in fact on the shelf and ready to ship, I'm not going to get too excited about it.
However, I do remain fairly optimistic about it actually happening though....
ST185 Narrow body Rally Car
ST205 engine transmission
Stocked with lots of go fast goodies....
400+bhp depending on boost.
kevzep
Postby mike@td.co.uk » Wed Dec 16, 2015 12:46 pm
Anyone who has any concerns, can contact Quaife UK themselves for confirmation that these are indeed in production for us:
https://shop.quaife.co.uk/contact-us
+44 (0)1732 741 144
info@quaife.co.uk
No payments will be taken until the units are here, I will post up in a separate thread nearer to the time. These Quaife units will happen 8) . We've got good interest in half of the units available thus far.
Again apologies for jumping onto your thread Eric.
Thanks
Mike
mike@td.co.uk
Postby TRDTurko » Mon Dec 21, 2015 5:16 pm
would the center diff be configurable to 1.5? it seems 2 way might be too harsh for tarmac driving causing under steer going into a corner.
88 Celica GTS - RIP
93 Honda Civic - RIP
85 Honda Civic - Sold
08 Mazda 3 - Daily
TRDTurko
Postby kevzep » Mon Dec 21, 2015 6:01 pm
TRDTurko wrote:would the center diff be configurable to 1.5? it seems 2 way might be too harsh for tarmac driving causing under steer going into a corner.
I do know on the Cusco plate LSD's you can change them between two different configurations by changing the ramps, but not all of them are....
personally I feel 1.5way would be better for tarmac and gravel.....I guess we will see what the specs are?
I wonder if we all specified on the Google document which we prefer perhaps they may take that into consideration...
kevzep
Postby rallygarage » Mon Dec 21, 2015 7:13 pm
Now if somebody could build us a sequential kit with rally ratios. Like maybe Samsonas or SQS. I will probably build SQS H pattern dog box next.
rallygarage
Postby kevzep » Mon Dec 21, 2015 7:21 pm
rallygarage wrote:Now if somebody could build us a sequential kit with rally ratios. Like maybe Samsonas or SQS. I will probably build SQS H pattern dog box next.
Would be next to impossible to change a H pattern to a sequential, the actual design is so different in terms of gear selecting, but I hear what you're saying.....You can buy a Maktrak which is sequential, but huge money....
All is not lost though, SQS does a sequential shifter which uses soleniods on a conventional H pattern gearbox for gear selection.
So the combination with the SQS Dog kit (where you can choose your final drive and ratios) and their own sequential add on, its all there.
kevzep
Postby rallygarage » Mon Dec 21, 2015 8:06 pm
They will need to fabricate a case and internals with a drum shifter like they do for Evo.. MacTrak is an Evo box installed on Celica with his adapter plate. You get into big money with transfer case and rear diff.
rallygarage
Postby eric thompson » Mon Dec 21, 2015 8:09 pm
I've been in touch with several firms about sequential transmissions... Maktrak is out of business, the owner passed away and the business closed down... Our options for 6spd sequential are limited and exorbitantly expensive...
ST165-PARTS-RED
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Postby rallygarage » Mon Dec 21, 2015 11:03 pm
In our rally shop we did business with Samsonas. They will do it of we get enough units ordered. It's no different then evo. And the only reason evo is so inexpensive is the numbers they make and sell.
rallygarage
Postby eric thompson » Tue Dec 22, 2015 4:24 pm
rallygarage wrote:In our rally shop we did business with Samsonas. They will do it of we get enough units ordered. It's no different then evo. And the only reason evo is so inexpensive is the numbers they make and sell.
How much is an Evo unit?? Maktrak used the same trans for us and Evo. The Celica's either had a diff bellhousing or just a BH apapter plate... the problem was the front diff ratio's available for the Maktrak dont match our rear diff ratio(2.929 if memory serves correct) and would require using their rear diff assembly(add $10k), have a custom ring and pinion made, or possibly swapping a Supra rear diff which has more ratio options but still requires loads of customization. My main concern aside from cost is serviceability... if I blow my trans at the track i'm screwed and down for how many weeks shipping it back and forth to whomever for repairs... it's a lot easier and hella cheaper to have a spare 185 or 205 box to use as a spare...
ST165-PARTS-RED
eric thompson
Images: 6
Postby alltracman78 » Wed Dec 23, 2015 12:02 am
The front diff gear ratio [which is the final drive] is completely unrelated to the rear diff ring/pinion gear ratio.
The gear ratio on the front diff is the final drive. Power is then transferred to the ring/pinion gear in the transfer case; which lowers the drive speed so the driveshaft spins slower. Then the rear diff ring/pinion gear raises the drive speed back to the original speed in the transfer case, so the rear wheels spin as fast as the fronts.
The transfer case ring/pinion gear is what matches the rear diff ring/pinion gear, not the front diff.
Postby eric thompson » Wed Dec 23, 2015 1:06 pm
alltracman78 wrote:The front diff gear ratio [which is the final drive] is completely unrelated to the rear diff ring/pinion gear ratio.
I only stated what I've read, heard from other GT4 owners, and what Maktrak also agreed with when we were in discussions about my options to avoid buying their rear diff assembly. The transfer appears to use a bevel gear and the center distributes power to the front and rear... Besides the front and rear ratio's would still need to be identical or the center diff would burn up front the front and rear spinning at different speeds. At least that's my understanding...
ST165-PARTS-RED
eric thompson
Images: 6
Postby Toyota1968 » Wed Dec 23, 2015 1:39 pm
My understanding is that with maktrak you are replacing not just gearkit but entire gearbox and transfer gearing meaning ratios exiting to rear may well be different
Toyota1968
