Need clutch master cylinder
Postby camry90 » Sun Dec 20, 2015 11:06 pm
I tried a to use LHD master cylinder on my RHD car but it doesn't fit because of the reservoir.
Is it easy to rebuild a master cylinder using repair parts found here in canada?
camry90
Re: Need clutch master cylinder
Postby yyonline » Wed Dec 23, 2015 4:40 am
Yes. For ST185 I'm assuming. Rebuild kit Toyota P/N 04311-22040 is the same for LHD and RHD cars. RHD clutch master cylinder is part number 31410-20510 if you want to search the internet for the entire assembly.
yyonline
Postby camry90 » Wed Dec 23, 2015 9:20 pm
thank you! i will give it a try on the new year
camry90
