Will the RX300 lsd differential fit anSt185 carrier housing?
Postby AwdGte » Mon Mar 28, 2016 8:20 pm
Or can it be used in place of, without having driveline mismatch issues?
If I have to fabricate mounts, that's no big deal.
AwdGte
Re: Will the RX300 lsd differential fit anSt185 carrier hous
Postby de_engineered » Mon Mar 28, 2016 11:06 pm
If you mean the rear dif, someone in the AllTrac.net Facebook group did it on a Camry Trac. Unsure other details, but if I'd be interested if you found out more. The axles fit too apparently, and add about 2" of track to a side, which may or may not be a good thing depending on your setup.
de_engineered
Postby AwdGte » Tue Mar 29, 2016 2:25 am
Great, do you have a link so I can look at that? Is the Camry all trac the same subframe and ratio as the Celica alltrac?
de_engineered wrote:If you mean the rear dif, someone in the AllTrac.net Facebook group did it on a Camry Trac. Unsure other details, but if I'd be interested if you found out more. The axles fit too apparently, and add about 2" of track to a side, which may or may not be a good thing depending on your setup.
AwdGte
Postby de_engineered » Tue Mar 29, 2016 2:34 am
Facebook Group Post
Subframe/diff drops in; only difference in the rear end are minor sway bar issues between the various generations. Diff ratio is either same or largely inconsequential. Not my area of expertise, but don't believe it's an issue.
de_engineered
Postby AwdGte » Tue Mar 29, 2016 4:22 am
Awesome, thanks!
de_engineered wrote:Facebook Group Post
AwdGte
Postby de_engineered » Fri Apr 01, 2016 2:40 pm
Here's the Toyota Nation thread on it, may lend some more insight.
de_engineered
Postby celica_gtx » Fri Apr 01, 2016 5:08 pm
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby RedCelicaTRD » Fri Apr 01, 2016 8:09 pm
celica_gtx wrote:.
That's a quality post right there!
Postby AwdGte » Fri Apr 01, 2016 8:35 pm
Rofl! No shit huh?
I thought the dude edited his post, but there is no edit time?
RedCelicaTRD wrote:
celica_gtx wrote:.
AwdGte
Postby celica_gtx » Sat Apr 02, 2016 2:49 pm
. = following don't get ur panties in a bunch I'm just as interested as u.
celica_gtx
Postby AwdGte » Sun Apr 03, 2016 4:43 am
You can subscribe at the top left.
I'll let you know what I find out, it looks like the innards will fit based on that post, but it'd be easier to use the entire carrier?
AwdGte
Postby underscore » Sun Apr 03, 2016 2:54 pm
Just hit the subscribe button, keeps the threads cleaner.
Does anyone know if an IS300/Altezza rear LSD will fit?
Edit: Looks like the ratios are wrong, Altezza is 41:10 and GTFour is 41:14
Postby celica_gtx » Mon Apr 04, 2016 8:44 pm
AwdGte wrote:You can subscribe at the top left.
it never saves them for me. IDK why
celica_gtx
Postby BlaznToyo88 » Thu May 05, 2016 1:53 pm
hi all, i was the one who did the Rx300 lsd diff install into my 88 camry alltrac, yes its a straight forward swap, diff installed in car already. havent driven it much to notice any difference.
BlaznToyo88
