camry heads to celica?
Postby Ryan » Tue Jul 12, 2016 2:29 am
will my bonestock 1988 camry awd engine heads fit on my 88 celica? if so this would save a lot of time and money!
-Ryan
Ryan
Re: camry heads to celica?
Postby underscore » Tue Jul 12, 2016 5:35 am
Which engine does each one have?
Postby Ryan » Tue Jul 12, 2016 3:10 pm
the celica has a gen 1 3sgte bone stock
the camry has the 3S-FE or 3S-GE i cant really remember...
-Ryan
Ryan
Postby ___Scott___ » Tue Jul 12, 2016 6:19 pm
Either head will bolt on, but coming from a Camry the head is most likely the FE version. That head is designed for fuel economy so it will not perform as well as the GE head (or the GTE head.) Neither the FE nor GE heads will have the mounting points for the WTA intercooler, but that's not really a problem. To get those mounting points you need the GTE head.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby Ryan » Tue Jul 12, 2016 9:50 pm
lol thanks so much, i found an old block an head with no valves for 200 but i think its second gen... would that be a better option?
Ryan
Postby alltracman78 » Wed Jul 13, 2016 1:11 am
Unless you want to change other parts too you're stuck using the 1st gen 3SGTE head.
