best st165 headgaskets??
Postby Ryan » Thu Jul 14, 2016 2:51 am
whats the best head gasket i can put in my st165, also i found an 88 jdm 3sgte tranny and turbo for 850 is that more economical?
Ryan
Re: best st165 headgaskets??
Postby ___Scott___ » Thu Jul 14, 2016 1:46 pm
The best head gasket is a multi-layer-steel gasket like this one:
http://www.koracing.net/viewproduct.php ... roduct=465
I recommend that you don't use stock head bolts with a MLS gasket though. I suggest a good set of studs like these:
https://twosrus.com/catalog/product_inf ... cts_id=185
Note: The studs will require greater torque (60 lb-ft if I remember right) than the stock 36 lb-ft.
Check out the Porterfield R4S brake pads at twosrus too. I have run them for a long time and highly recommend them.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby Ryan » Thu Jul 14, 2016 7:22 pm
mine is first gen though, will they still fit
(the gasket)
-Ryan
Ryan
Postby ___Scott___ » Thu Jul 14, 2016 11:56 pm
They fit. They are the same parts I recently put on my 1st gen.
Scott
SONY
___Scott___
