Another ACPT C/F Driveshaft 7/2016
Re: Another ACPT C/F Driveshaft 7/2016
Postby ChrisD » Wed Dec 14, 2016 6:52 pm
I received this from Ryan today as I asked about tracking #s:
Good morning Chris,
The shafts were coming back in from the balancing company yesterday. I have been travelling on business so was not aware of the delay. Turns out the 4 bolt flange required was on back order which impacted our delivery schedule. However, this has been resolved and shafts are being completed. Please share this information with the group.
Thanks again,
Ryan Clampitt
1988 ST165
1994 ST205 WRC
ChrisD
Postby ChrisD » Thu Dec 15, 2016 9:42 pm
He also mentioned that he would send out tracking numbers. Soon enough!
1988 ST165
1994 ST205 WRC
ChrisD
Postby ChrisD » Fri Dec 16, 2016 9:24 pm
Just received my tracking #. :)
1988 ST165
1994 ST205 WRC
ChrisD
Postby ChrisD » Sun Dec 18, 2016 4:19 pm
Arrives Friday for me, just in time for Christmas!
Sent from my Pixel using Tapatalk
1988 ST165
1994 ST205 WRC
ChrisD
Postby BayAreaAT® » Mon Dec 19, 2016 6:24 am
Got mine yesterday.. WOW!!! :D :D :D :D :D :D ear to ear.
Chris M.
91 ST185 "money sponge"
Ford Ford (Daily Grind)
R1 Yamaha ( Need for speed)
Ford F150
Chrysler 300c Hemi baby!!
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby 3SDNA » Mon Dec 19, 2016 10:56 am
Awesome guys! Has anyone else seen a tracking number yet? I have not received any emails.
3SDNA
Postby BayAreaAT® » Mon Dec 19, 2016 11:03 am
I didnt get any tracking. I just showed up... yours could be on its way. Ill be doing my installation later. Ill take picture for you guys.
Chris M.
Ford F150
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby milehigh_alltrac » Mon Dec 19, 2016 2:35 pm
I just got my tracking # this morning and it says it is getting delivered today!
milehigh_alltrac
Postby zaluss » Sat Dec 24, 2016 10:44 pm
Installed it today but ran into an issue or at least potentially an issue. It seems a bit shorter than the OEM prop shaft and the OEM shroud does not fit. I compared it to the drawing and it measures as the same as the drawing.
Video installed and running:
https://www.youtube.com/watch?v=mHpHPRSSD34
zaluss
Postby 3SDNA » Sat Dec 24, 2016 11:54 pm
Yeah, that looks like an issue!
3SDNA
Postby ChrisD » Mon Dec 26, 2016 4:30 pm
Lots of discussion on the Facebook group about this, for those not on there. Might be good to keep some of the discussion here so that it actually helps people in the future.
zaluss/Mike: can / did you measure the length of both yokes? I can probably get to that later this week if you can't. It almost looks like the yoke is all that's too short. Perhaps one option is to use a different yoke.
There are a few confirmed reports of people running these without issue, at the 79.5" length. Others have countered that this may be an issue with high powered cars. Mine would fall in the high powered camp at 4-500whp, running a twin plate clutch and plan to launch quite hard. However, I also have solid engine and rear diff mounts so the play is at a minimum. I would expect the same for anyone running this kind of power.
Another option is a spacer plate at the diff side, which would likely be pretty easy. That might be an option.
1988 ST165
1994 ST205 WRC
ChrisD
Postby zaluss » Mon Dec 26, 2016 5:34 pm
ChrisD wrote:Lots of discussion on the Facebook group about this, for those not on there. Might be good to keep some of the discussion here so that it actually helps people in the future.
Unfortunately I did not do a comparison measurement of the transmission yokes themselves however in the picture I laid out the two prop shafts are the diff end. The actual transmission yoke appears to be identical in length.
I can measure the OEM yoke length since I have it out and if you want to measure the ACPT yoke length but per Toyota, the Supra and the ST165/185 used the same yoke.
Part 37302-35030 (YOKE SUB-ASSY, UNIVERSAL JOINT SLEEVE) was found on the following models:
Date range Model Frames/Options Found in diagram
08/1987-07/1989 TOYOTA CELICA AT160,ST16* 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
10/1989-10/1993 TOYOTA CELICA AT180,ST18* 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
01/1986-07/1988 TOYOTA SUPRA MA70 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
08/1988-04/1993 TOYOTA SUPRA MA70 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
10/1988-01/1993 TOYOTA CRESSIDA GX71,MX75,YX72,RX7* 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
05/1990-11/1999 TOYOTA PREVIA TCR1*,2* 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
08/1983-06/1998 TOYOTA HILUX LN5*,6*,YN5*,6*,RN5*,6* 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
11/1995-07/2002 TOYOTA 4RUNNER RZN18*,VZN18* 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
08/1997-07/2005 TOYOTA HILUX KDN1**,LN1**,RZN168,173 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
08/1987-04/1995 TOYOTA DYNA 100 YH81,LH80 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
05/1995-07/2001 TOYOTA DYNA 100 LY100,YY100 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
12/1982-06/1988 TOYOTA HIACE YH5*,6*,7*,LH5*,6*,7* 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
08/1989-01/2006 TOYOTA HIACE LH1**,RZH10*,11*,125,135,15* 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
08/1989-07/1995 TOYOTA HIACE LH10*,11*,RZH10*,11* 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
08/1995-10/2011 TOYOTA HIACE, HIACE S.B.V KLH1*,2*,LXH1*,2*,RCH1*,2* 37-01: PROPELLER SHAFT & UNIVERSAL JOINT
zaluss
Postby ChrisD » Tue Dec 27, 2016 2:11 pm
Oh ok, must just be the angle and my eyes. To be honest, the more I look at this the less I worry about it. With solid motor and rear diff mounts, my setup does not move. That and this shaft has one fewer joint to provide that play, I think this will be totally fine. I might try it and if something happens, then make a spacer. I'll have this on the dyno before it sees the road, so I can see how things go in a controlled environment first.
1988 ST165
1994 ST205 WRC
ChrisD
Postby zaluss » Tue Dec 27, 2016 6:19 pm
ChrisD wrote:Oh ok, must just be the angle and my eyes. To be honest, the more I look at this the less I worry about it. With solid motor and rear diff mounts, my setup does not move. That and this shaft has one fewer joint to provide that play, I think this will be totally fine. I might try it and if something happens, then make a spacer. I'll have this on the dyno before it sees the road, so I can see how things go in a controlled environment first.
I drove it hard yesterday and I was pretty impressed with the difference. Didn't see any issues.
That said, I ordered the Supra dust shield and I'll do a test fit once I receive it to close the gap and make me feel better about the seal. I'll throw my GoPro underneath the car one of these days to see if we can capture the movement.
zaluss
Postby fhalperformance » Wed Dec 28, 2016 12:26 am
The shafts are identical to the original group buy in length and overall design per a friend who posted up pictures on the facebook group. No ones had any issues with that group buy over the last several years including some high powered cars as far as I have read.
Has anyone actually measured how much of the transfer case output shaft the driveshaft slips onto is actually splined? I got a couple transmissions apart right now I can see about a measurement tomorrow night but I doubt they have the same length of splines the factory driveshaft has. The front axles only have a couple inches of splines where they engage the transmission and we have seen some significant power flow through them in comparison to stock.
For all the shafts that have been used with solid mounts and the like over the years of abuse I think we would've heard something by now if there was an issue.
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
