Another ACPT C/F Driveshaft 7/2016
Re: Another ACPT C/F Driveshaft 7/2016
Postby 801Alltrac » Tue Aug 02, 2016 1:47 am
Submitted..and verified by Ryan clampitt
Super excited guys !
801Alltrac
Images: 13
Postby DeeCee » Tue Aug 02, 2016 1:49 am
abraxxa wrote:As I said in the other thread I'm interessted in a ST205 version.
Note, that when the last ACPT C/F driveshaft group buy was made, the driveshaft requires some brackets on the tunnel to be removed, so it won't be a straight fit.
If I remember, Wolf had to remove the centre hanger carrier bracket or something along those lines, to fit the driveshaft due to the diameter of the CF tube.
Getting some dimensions would be helpful in determining if the C/F driveshaft is suitable for ST205.
DeeCee
Postby zaluss » Tue Aug 02, 2016 1:55 am
Also sent mine to Ryan.
zaluss
Postby ChrisD » Tue Aug 02, 2016 5:02 pm
I measured my 205 and 165. The 205 is about 3/4" longer than the 165. This would seem consistent with the longer wheelbase of the ST205. So I'd say it's a no go. :(
1988 ST165
1994 ST205 WRC
ChrisD
Postby zaluss » Tue Aug 02, 2016 5:41 pm
That sucks :(
So the ST185 and ST165 have identical prop shafts? Are they interchangeable in OEM form? Or just the same length?
zaluss
Postby BayAreaAT® » Tue Aug 02, 2016 5:43 pm
I measured my 205 and 165. The 205 is about 3/4" longer than the 165. This would seem consistent with the longer wheelbase of the ST205. So I'd say it's a no go. :([/quote]
That sucks :(
So the ST185 and ST165 have identical prop shafts? Are they interchangeable in OEM form? Or just the same length?[/quote]
Interchangeable..
Chris M.
91 ST185 "money sponge"
Ford Ford (Daily Grind)
R1 Yamaha ( Need for speed)
Ford F150
Chrysler 300c Hemi baby!!
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby fhalperformance » Tue Aug 02, 2016 6:16 pm
Did you see my post about pricing?
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Postby ChrisD » Tue Aug 02, 2016 6:47 pm
BayAreaAT® wrote:So the ST185 and ST165 have identical prop shafts? Are they interchangeable in OEM form? Or just the same length?
This is an assumption I have made based on previous comments. Can someone confirm? I could probably get under a 185 in the next few days, I just don't have one in my garage...
1988 ST165
1994 ST205 WRC
ChrisD
Postby underscore » Tue Aug 02, 2016 7:07 pm
If I remember right these work for the 205 with a spacer. The 185 and 165 driveshafts have the same part number.
Postby BayAreaAT® » Tue Aug 02, 2016 7:38 pm
If its only spacers needed. I can have a machine shop make an adapter
Chris M.
Ford F150
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby underscore » Tue Aug 02, 2016 9:06 pm
I skimmed the old thread, on page 29 DarthRipley mentions it's 5mm too short for the 205, I imagine a spacer could easily be fitted between the shaft and the rear diff but I'm not an expert on these things. I saw elsewhere the 205 trans requires a dust shield to be trimmed a bit but that's not a big deal. If anyone has a 205 I'd suggest reading the old thread fully to see what has already been determined.
ChrisD are you guys bringing a 205 down for the Ogopogo? I think my ACPT shaft is still gathering dust if someone feels like taking the time for a real test fit.
Postby pintoBC_3sgte » Tue Aug 02, 2016 10:25 pm
there should be a few 205's at the ogopogo
pintoBC_3sgte
Postby killemalltrac » Tue Aug 02, 2016 11:46 pm
205 shaft is definitely longer. I had one from my front clip and side by side with the 165 DS it wasn't the same.
#80sMurderCar
killemalltrac
Images: 10
Postby fhalperformance » Wed Aug 03, 2016 3:14 am
I have a loose st185 and a loose st205 driveshaft I should compare them.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby ChrisD » Wed Aug 03, 2016 12:57 pm
underscore wrote:I skimmed the old thread, on page 29 DarthRipley mentions it's 5mm too short for the 205, I imagine a spacer could easily be fitted between the shaft and the rear diff but I'm not an expert on these things. I saw elsewhere the 205 trans requires a dust shield to be trimmed a bit but that's not a big deal. If anyone has a 205 I'd suggest reading the old thread fully to see what has already been determined.
Yeah there will be a few. I'll have mine there. I've measured my car as well as the 165, definitely different. A spacer would probably suit the bill for any 205 owners that want one. The one I'm getting is for my 165.
1988 ST165
1994 ST205 WRC
ChrisD
