Clutch for 500-600ftlbs? 500-600hp
• Page 1 of 1
Hi,
Looking Street-friendly clutch for 500-600ftlbs? 500-600hp for ST185. Reliable and with good price
(I understand that is not reality, but what would you use)
Any suggestions?
Any suggestions?
- lordvampire
Re: Street-friendly clutch for 500-600ftlbs? 500-600hp
Sounds like a stage 3 or multi plate clutch. I have a stage 2, and mine can be quite "digital" (either on or off
) I think mine is an exedy unit and once you get used to it, it behaves like a normal clutch
Sent from my Nexus 9 using Tapatalk
- audiodjmp77
I have Exedy Hyper single disc. Normally 1200$.. it's yours for 850.00 +shipping
Chris M.
91 ST185 "money sponge"
Ford Ford (Daily Grind)
R1 Yamaha ( Need for speed)
Ford F150
Chrysler 300c Hemi baby!!
BayArea,California
www.Boost2maxx.com
Ford F150
BayArea,California
www.Boost2maxx.com
BayAreaAT® - Established Member
I'm looking for similar power levels and selected an OS Giken R2CD. Not cheap but you asked what we'd go with, and that's what I went with. Perhaps you could get away with a single disk but would depend on which one specifically and your intended use. (i.e. will you be launching it?)
1988 ST165
1994 ST205 WRC
1994 ST205 WRC
- ChrisD
OS Giken .. is what I have been suggested various places now... seems like real option.
https://www.nengun.com/os-giken/racing- ... ate-racing
Other-one, not so obvious, is SPEC Clutches. Got the answear:
"The st3+ is a very street friendly unit and holds 555 ft lbs. If that is not enough capacity, then stage 5 (670 ft lbs) or the twin disc (800 ft lbs) are streetable options, just not as friendly as the 3+."
Now... the st3+ 555ft lbs (750+nm) its enough. Sounds super, has anyone used "SPEC Clutches" products? It is tempting.
Edit: not launching. Track race (tarmac) and street drive.
- lordvampire
Re: Clutch for 500-600ftlbs? 500-600hp
Got in my hand OS Giken Super Single
Its rated 400whp(480hp) / 539nm ? ...
I have 409kw/~550hp,.. will it be little weak... or it has little extra ? (I just got the the kit next to nothing)
- lordvampire
My guess is that that clutch would slip with your power level
1988 ST165
1994 ST205 WRC
1994 ST205 WRC
- ChrisD
My fears are confirmed .... cheap solution hopes faced reality
. Then shopping is the answer.
- lordvampire
Ha. The clutch is one of those jobs you just don't want to have to do twice.
1988 ST165
1994 ST205 WRC
1994 ST205 WRC
- ChrisD
• Page 1 of 1
