New Shifter Cable Group Buy
Postby CSAlltrac » Tue Dec 13, 2016 9:27 pm
Just as the title says, who would be interested in participating? Myself and Toayaztan are two, company I found said the more that buy the cheaper the cables will be.
Re: New Shifter Cable Group Buy
Postby rrain3288 » Tue Dec 13, 2016 10:44 pm
depending on the price. im interested
Why me!!!!
92 Celica Alltrac-gen 3 swap
rrain3288
Postby RafaCalde » Tue Dec 13, 2016 11:05 pm
Definitely interested!
Rafa
RafaCalde
Postby CSAlltrac » Tue Dec 13, 2016 11:19 pm
He gave me a very rough estimate of $150 per cable so $300 a set. I'm in need of 90-91 cables and will be sending him my current, bent set as a template. The members in need of a 92-93 set would need to come up with a set of cables to send as a template. Bryan (Toayaztan) said he may do this. I will be sending my cables to them next week after this weekends track day so 90-91 variant should be ready to be made by middle of January. I think if there's at least 5-10 committed buyers $80-100 a cable would be very doable. Here is a link to the company I am talking to.....
http://www.controlcables.com/custom-shift-cables/
Postby rrain3288 » Wed Dec 14, 2016 12:48 am
Was there a difference in the cables over the years ...I never knew
Why me!!!!
rrain3288
Postby CSAlltrac » Wed Dec 14, 2016 1:59 am
rrain3288 wrote:Was there a difference in the cables over the years ...I never knew
Yes, the 92-93 has different ends on the trans side from what I've been told.
Postby Locker » Wed Dec 14, 2016 2:23 am
im very interested.... hopefully under $100 a cable but I will follow the thread
90 ST185
Locker
Postby aus jd 2703 » Wed Dec 14, 2016 5:11 am
Are they the same lhd to rhd? If so I might be in cost allowing
aus jd 2703
Postby CSAlltrac » Wed Dec 14, 2016 11:42 am
aus jd 2703 wrote:Are they the same lhd to rhd? If so I might be in cost allowing
This is a good question. Maybe someone else can chime in.
Postby eric thompson » Wed Dec 14, 2016 7:31 pm
I'm interested!
Sent from my XT1650 using Tapatalk
ST165-PARTS-RED
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Postby fussellbug » Wed Dec 14, 2016 8:47 pm
Part numbers for JDM and USDM cables were the same 33821-20700 + 33822-20271 (90-91) and 33821-20870 + 33822-20393 (92-93).
The 90-91 and 92-93 cables should be interchangeable simply by using bushings that fit the diameter of the cable ends.
fussellbug
Images: 36
Postby underscore » Thu Dec 15, 2016 5:03 am
^ meaning the 92-93 have one larger end on the trans side. IIRC you can swap cables between the pre and post facelift as long as you have the correct bushing (which I imagine would come with these cables). I assume the post might be an upgrade of some sort, but who knows.
Postby CSAlltrac » Sat Dec 17, 2016 4:05 am
Spoke to the guys that would be making them again. The cables that they would provide would be about 85-90% dialed in requiring some trial and error in getting them installed on each different car. That said I will probably go forward with getting a set made and see what has to be done. Might be a real pain to go this route. Their cable ends will have threaded portions that would allow different heims to be utilized on the trans side. The shifter side may require robbing the stock cables of their ends and securing them to the new cables somehow. One thing I know for sure is having a bent cable is very, very frustrating.
Postby toayoztan » Sun Dec 18, 2016 5:48 am
CSAlltrac wrote:Spoke to the guys that would be making them again. The cables that they would provide would be about 85-90% dialed in requiring some trial and error in getting them installed on each different car. That said I will probably go forward with getting a set made and see what has to be done. Might be a real pain to go this route. Their cable ends will have threaded portions that would allow different heims to be utilized on the trans side. The shifter side may require robbing the stock cables of their ends and securing them to the new cables somehow. One thing I know for sure is having a bent cable is very, very frustrating.
If the new cables can't be made from scratch, then I don't think I can send in my cables (since mine still work). I was more or less just wanting an alternative or fresh set of cables to work with (for that JIC or What if moments).
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby hoys » Sun Dec 18, 2016 2:53 pm
For my 165 I used California Push-Pull. Sending in the old cable to reuse both ends (front back cable) and the price was 154 with shipping. Cable was very nice and they even provided new fire sleeve material for the cable. Well worth the price for the cable that always breaks!
hoys
