Who has ran the ST185 in FWD mode?
Postby AwdGte » Mon Jan 09, 2017 4:19 am
I've read the warnings about putting the trans in FWD mode, has anyone actually done this?
For a burn out to heat up the front tires at the track or to dyno the car on a 2wd dyno?
If your response includes "don't do this" or the like, can you explain the technical reason in detail as to why?
Thanks
AwdGte
Re: Who has ran the ST185 in FWD mode?
Postby FC Zach » Mon Jan 09, 2017 4:37 am
I wont simply because the manual says for testing purpose only and if I recall there is a limit to the amount of power that can be applied while in this mode. . so with that said, a dyno may be out of the question for you. There's s lot of vague information I've gathered from this selector but most of what I got from others is to leave it alone.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby CMS-GT4 » Mon Jan 09, 2017 11:52 am
Plenty have dyno'd in fwd mode. There are very specific instructions contrary to the manual. Do a quick search and there should be a thread that covers them. It does advise against any distance driving and I think it explains why.
Postby underscore » Mon Jan 09, 2017 3:22 pm
You can use it on the dyno (that's what it's for IIRC) but if you wanted to heat up the tires with a burnout I think they'd be mostly cooled down by the time you got under the car and changed it back to 4WD. The main thing is to ensure the rear wheels absolutely do not move while in 2WD mode or there's an important piece inside that will break if you try to do more than limp it a few feet in a straight line. The other thread covers it in more detail.
Postby AwdGte » Mon Jan 09, 2017 4:59 pm
Ok, I found these (and a bunch of broken links also), should I read anything else?
viewtopic.php?f=43&t=43503&start=30
viewtopic.php?t=34172
viewtopic.php?f=7&t=22453&start=60&mobile=desktop
AwdGte
Postby ChrisD » Wed Jan 11, 2017 4:49 pm
http://www.celicatech.com/forums/showth ... n-2WD-Mode
I have done it. No issues at 250whp or so. I have heard of issues at higher power levels.
1988 ST165
1994 ST205 WRC
ChrisD
Postby AwdGte » Wed Jan 11, 2017 5:13 pm
Has anyone used the ST185 center diff on the ST205 trans and ran it in fwd mode?
AwdGte
