Removing the transmission from the engine
Postby awdmofo » Thu Feb 02, 2017 6:18 am
So I finally got the engine/trans out of the car. The BGB shows little pictures and information about how to disconnect the trans from the engine. I assume there are many various bolts that need to be removed then it should slide off the engine. The BGB just says "pull trans 2-3 inches straight away from the engine" then shows some arrow pointing to the front of the trans saying to slide/push it to the right away from the engine, then next shows another arrow pointing straight away from the engine. HELP :cry: :cry: :bangshead: :bangshead:
Thank you!
2013 Camaro LS 6-sp (daily)
2005 Yamaha R6 (sold)
2001 Spider (sold)
1990 alltrac (sold)
1991 MR2 turbo x2 (Sold)
awdmofo
Re: Removing the transmission from the engine
Postby MrDB » Thu Feb 02, 2017 7:14 am
Undo all bolts, pul transmition off it then needs to rotate to clear block then continue to pull off.
Easier to put engine on cambelt end and drop transmition back on from above when replacing. ( use hoist )
MrDB
Postby FC Zach » Thu Feb 02, 2017 7:25 am
MrDB wrote:Undo all bolts, pul transmition off it then needs to rotate to clear block then continue to pull off.
Definitely easier said than done, it took me a while to get mine separated.
MrDB wrote:Easier to put engine on cambelt end and drop transmition back on from above when replacing. ( use hoist )
This is what I ended up doing.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby zaluss » Thu Feb 02, 2017 1:04 pm
I found it easiest to rotate the engine on its side and use the 'silo' method.
zaluss
Postby JRWperformance » Thu Feb 02, 2017 5:36 pm
I too did the silo method. It really is the best way to do it. Set the engine on a thick chunk of cardboard on the crank pulley. Then use an engine hoist to pull the trans up. Massively easier
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Postby rallyst185 » Thu Feb 02, 2017 7:20 pm
Massively easier to install it that way too!!! Even with a good clutch alignment tool it can be a PITA
rallyst185
Postby awdmofo » Thu Feb 02, 2017 9:00 pm
I do have an hoist so that is possible. Dumb question but which bolts do I remove. It looks like the transmission has bolts that maybe connect just to the engine, maybe some that connect just to the transfer assembly ect...
JRWperformance wrote:I too did the silo method. It really is the best way to do it. Set the engine on a thick chunk of cardboard on the crank pulley. Then use an engine hoist to pull the trans up. Massively easier
Silo method?? :shrug: :shrug:
zaluss wrote:I found it easiest to rotate the engine on its side and use the 'silo' method.
Thanks for the pics, is that a 185 engine/trans though? I see a 165 hiding there :D. What I am working with here...
2001 Spider (sold)
1990 alltrac (sold)
awdmofo
Postby zaluss » Thu Feb 02, 2017 9:24 pm
That is a 205 engine that I swapped into my ST165.
Should be essentially the same concept. You want to rotate the crank pulley on its side (on something like a old thick pillow like I did) and then pull the trans up via the hoist. Without the head, you may have some balancing issues this way.
zaluss
Postby awdmofo » Thu Mar 16, 2017 6:05 pm
So what I actually did was disconnect the front diff from the trans and kept it bolted with a bracket to the block. lifted the engine on one side and only had to lift like not even a foot and the trans slid right off the block. Much easier than I expected.
2001 Spider (sold)
1990 alltrac (sold)
awdmofo
