Limp mode tow?
Limp mode tow?
Postby Ryan » Sun Feb 05, 2017 11:57 pm
could I tow my car on a tow dolly if I put it in fwd limp mode or removing the driveshaft?
Ryan
Re: Limp mode tow?
Postby Nobody » Mon Feb 06, 2017 1:40 am
Tsrm Does not recomend dolly on front wheels only. Would want to put a dolly on the rear and crane the front up.
If you leave the rears on the ground the front wheels need to spin freely otherwise the drivetrain could heat up and burn out.
Tsrm shows tow strap is OK too. As long as the front's and rears are turning together should be ok. Car in neutral and parking brake off.
Took a screenshot of the page in the tsrm but I'm not seeing a way to upload it.
Nobody
Re: Limp mode tow?
Postby MWP » Mon Feb 06, 2017 10:50 am
Nobody wrote:Tsrm Does not recomend dolly on front wheels only. Would want to put a dolly on the rear and crane the front up.
That sounds like the TSRM for a ST205.
The ST185's have the FWD selection lever on the gearbox for exactly this purpose.
Re: Limp mode tow?
Postby FC Zach » Mon Feb 06, 2017 12:24 pm
It does explain this and show pictured examples of proper towing methods for a 185 in my manual, it never said anything about switching the lever.
I may have overlooked that, I'll have to check to see if that's an option next time I'm in the book.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Re: Limp mode tow?
Postby 88_ST165 » Mon Feb 06, 2017 2:25 pm
Ryan wrote:could I tow my car on a tow dolly if I put it in fwd limp mode or removing the driveshaft?
Yes you can, IF you disconnect the driveshaft at the rear diff, and make SURE you're using a dolly that is supporting front wheels IE: no flat tow (front wheels turning).
You wont have to adjust the AWD/FWD mode selector.
Dave MacLaurin
- 1999 Toyota 4Runner SR5 V6 (5mt)
- 1971 Datsun 240Z (Series 1, EFI, 5mt)
- 1972 Toyota Celica ST (4AGE Bluetop, 5mt)
- 1988 Toyota Celica Turbo 4WD
- 1989 Toyota Celica GT-S
88_ST165
Re: Limp mode tow?
Postby underscore » Mon Feb 06, 2017 3:18 pm
If you use the selector I believe you need to tow it with the front wheels on the ground and the rear wheels in the air, otherwise you'll break things. Make absolutely sure you put the selector in the correct position and put the bolt back in tightly, there's a story of a guy who dyno'd in 2WD mode but didn't put the bolt in, the selector shook out of 2WD mode while on the dyno and things got broken.
Re: Limp mode tow?
Postby MWP » Wed Feb 08, 2017 9:39 am
underscore wrote:If you use the selector I believe you need to tow it with the front wheels on the ground and the rear wheels in the air, otherwise you'll break things.
What would break?
Re: Limp mode tow?
Postby FC Zach » Wed Feb 08, 2017 12:23 pm
Hi
There are specific instructions in regards to towing, within the manual. I double checked and nothing is mentioned about the use of this selector.
Edit: ". . nothing is mentioned about the use of this selector." Except to leave alone "no special operation necessary".
FC Zach
Images: 9
Re: Limp mode tow?
Postby underscore » Wed Feb 08, 2017 4:33 pm
What would break?
It's a piece inside the transmission, from memory it's the part that the selector moves to disconnect the rear wheels. It can handle moving a few feet, but if the rear wheels turn at any significant speed it will break.
edit: from here: viewtopic.php?f=43&t=43503&start=30
loudstealthGT-Four wrote:
sleeper wrote:There is a guy here with a (tjdubble07) who tuned his high hp car in 2wd mode, and if i`m not remembering wrong, he found out that the gearbox would take about 500ft punds before it broke in fwd mode.
HAHA yea just DON'T drive on the road in FWD mode as it only takes a couple minutes for this to happen
which is this part in the centre diff
