Blowing oil out of the dips tick when in full boost..
Postby Shallow Pockets » Sat Feb 18, 2017 10:59 pm
I just got my st165 back on the road after a 2yr rebuild. My first hard boost and it started to smell like oil. I check all of my AN fitting and no leaks. Looked at my dips tick tube and it's drenched. I have no idea how to pipe the pvc system being that it doesn't have a pcv port and check valve. I'm just winging it. And help would be appreciated. Oh btw it has a catch can piped in and it's not doing its job....
Shallow Pockets
Re: Blowing oil out of the dips tick when in full boost..
Postby underscore » Mon Feb 20, 2017 5:22 am
Maybe a dumb suggestion but could the catch can be blocked? If it isn't catching any oil try removing it.
Postby Shallow Pockets » Mon Feb 20, 2017 5:33 am
Actually found the problem about 20 min ago. The pcv vent hose has a restrictor. I have no idea why. But it's fixed
Shallow Pockets
