st165,st 185, st105 trans questions
Postby outinnowhere3193 » Sat Dec 23, 2017 2:16 am
my car is the 165. I know depending on year and model the gear ratio changed. So if I change the transmission does that mean I have to swap out my rear gear ratio as well to match or is all the changes done before hitting the center diff?
Guess what I'm saying did the transmission gears just change or did the final gears change as well?
outinnowhere3193
Images: 5
Re: st165,st 185, st105 trans questions
Postby ___Scott___ » Sat Dec 23, 2017 1:48 pm
The final gear ratio is the same for all the different trans options. You can swap in any of them without worrying about the diff ratios.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
