Meurz":5d61kujk said:What are the specs on those wheels? (18x?) Offset? 8)
Different tire width also?Simba":aok5aw4a said:18x9" rear, 32 offset with a 15mm spacer.
Conan":32dtcgig said:Different tire width also?Simba":32dtcgig said:18x9" rear, 32 offset with a 15mm spacer.
Conan":3kilpsa4 said:Different tire width also?
Simba":1sz6ahbx said:Conan":1sz6ahbx said:Different tire width also?
At the moment, they're both 255/40, which fit both wheels well. In future, I'm probably going to go to 245/40 up front and 275/35 out back, assuming I can squeeze 'em in.
turbo4wd":3powsuo7 said:I have a feeling this may pose some potential problems to your diff.. your front tire/wheel combo is taller than your rear tire/wheel combo..
Won't that cause more traction on the rear = wearing the center diff :shrug:Simba":2x02o0vk said:In future, I'm probably going to go to 245/40 up front and 275/35 out back, assuming I can squeeze 'em in.
Conan":d85m864l said:Won't that cause more traction on the rear = wearing the center diff :shrug:
Pimp! Pimp! Hooray!Simba":2cw0scg3 said:If I had any intention of drag racing it, I'd probably be somewhat concerned. But then, if I were going to, I'd be using different tires (and wheels) alltogether.
