Today I was at the dragstrip to test the car, I had this feeling that my headgasket was blown acouple of days ago because the engine began to run a little warmer than usual, I thought it was maby the thermostat that jamed so I checked it and drilled a couple of holes in it just to be on the safe side(no time to get a new one).
After the second run at the quarter the temperature skyrocked and I noticed that I only had 15psi of boost instead of my usual 22psi, and to top the day my TRD clutch gived up on me :x
But I did manage to run 13.24sec/ 168km/h with slipping clutch, 15psi and a blown head gasket, not to bad I think. Would probably run a low 12 with everything working and 22 psi boost.
Well, I wount be racing more this year, will most likely rebuilt the whole engine.
Will be a boring summer without my GT-4
