Drag st165 Time to build a 5SGTE!
Re: Drag st165 Time to build a 5SGTE!
Postby 2of81 » Thu May 05, 2011 1:40 am
Lookin sweet, love the custom parts and the quality of them, that crank sensor bracket looks very nice! Keep up the great work!
Justin
1972 Corolla TE27
2of81
Postby Klas » Tue Jun 28, 2011 6:14 pm
Will run direct fire ignition with Ls2 truck coils. The aluminium bracket I think I will powdercoat black and the coil "wraps" will be red.
The valvecover will be coated shrinkle red.
Relocated oilfilter, BIG filter without pressure valve and checkvalve. Will install a cooler aswell.
1/4 in 12.577s 176km/h so far
If you can turn, you drive to slow!
Now on youtube!
http://www.youtube.com/watch?v=hSD6LlwS830
Klas
Postby Klas » Wed Jun 29, 2011 3:21 pm
Coated and installed :)
Now on youtube!
Klas
Postby sleeper » Wed Jun 29, 2011 5:12 pm
Looking good..
But when are you going to get this thing on the road? Would be cool to see you sett some nice times with it..
sleeper
Postby Klas » Wed Jun 29, 2011 7:09 pm
Thanks,
There are som stuff to be made before I can fire it up. Build the evac system, finish the oiling system,wire the coils, sparkplugwires, etc. etc.
I had plans on building a better exhaust manifold, but I will do that next winter instead.
Hopefully I will have her running soon.
Now on youtube!
Klas
Postby MWP » Wed Jul 20, 2011 2:57 am
Did your 5S block have mounting points for the mid transfer case mounting?
Mine does not, so im wondering what to do about it...
Postby Klas » Wed Jul 20, 2011 7:49 am
I ended up with grinding even more of the block than this picture shows.
I don´t remember, but I think that as for the middle bracket, It was just one hole missing.
Can´t remeber, but I think my block had the holes already (inside your green lines)
Now on youtube!
Klas
Postby MWP » Wed Jul 20, 2011 12:29 pm
Ahh yeah, i did see that photo but didnt notice the mid gbox mount hole just above the chuck.
Damn, i wonder why mine doesnt have any, might have to look into having them welded on :(
Postby Klas » Wed Jul 20, 2011 2:38 pm
MWP wrote:Ahh yeah, i did see that photo but didnt notice the mid gbox mount hole just above the chuck.
My block is a 99` camry, and it had almost every holes I needed for brackets.
I would not recomend you to weld the block, as it will most likely crack when you put some force and vibration on it. DO NOT WELD!
It´s much better to make a custom bracket and use some existing holes or drill/tapp holes at a suitiable location.
As for the grinding, 1 grind like hell! 2 Test fit the block to transmission, 3 grind like hell, 4 test fit. Tip, test fit with out the clutch at first, then test fit with the clutch just in case.
I thought I was home free but when I had my block coated, and assambled the tranni and block with the twin disc clutch, it would not fit.
Now on youtube!
Klas
Postby MWP » Wed Jul 20, 2011 9:32 pm
The problem is, as you can see, there is nothing around that area of the block at all i can bolt to :(
I also really need to have this done. A port added for proper oil cooler flow.
There is no other way to get a decent coolant flow through the cooler. The Gen2/5S way of doing it is no where near as effective as the gen3.
Ugh... a 5S crank in a Caldina block would have been so much easier :(
Postby Klas » Mon Nov 28, 2011 6:00 pm
FINALLY!!!! I have pulled my thumbs out of my ass and started my new engine :D
And it runs!
Some idle tuning left to do, then tune the antilag.
Now on youtube!
Klas
Postby Terracar » Mon Nov 28, 2011 8:51 pm
Sweet! Pics or it didn't happen!
:twisted:
-Terracar
Terracar
Postby Klas » Tue Nov 29, 2011 7:36 pm
Terracar wrote:Sweet! Pics or it didn't happen!
:twisted:
-Terracar
Now on youtube!
Klas
Postby alltracst185 » Thu Dec 01, 2011 12:40 am
Looks awesome bro! :D Now get a video of her purring ASAP! Again congrats!!!
alltracst185
Postby Klas » Thu Dec 01, 2011 6:03 am
alltracst185 wrote:Looks awesome bro! :D Now get a video of her purring ASAP! Again congrats!!!
Thanks!
A video will come, just have to order a new low temp thermostat (77C) from the US.
Discovered that my thermostat (82C) had really poor flow and didn open as much as I want (poor circulation).
I also need to fix a very small oil leak at the turbo inlet flange.
So, you have to wait a couple of weeks :wink:
Now on youtube!
Klas
Users browsing this forum: Bing [Bot] and 3 guests
