Drag st165 Time to build a 5SGTE!
Re: Drag st165 Time to build a 5SGTE!
Postby Terracar » Thu Dec 01, 2011 2:44 pm
:shock: Beautiful. :notworthy: Can't think of any other words.
-Terracar
Terracar
Postby rio_cyber » Fri Dec 02, 2011 5:46 pm
is it snow yet...
where are hi speed winter fun videos of alltrac in the 2 meter snowbanks eviroment
snow videos or ban
drag race is lame
4x4 snow drifts on touge are funnnnn
its fun - incoroprate gt4 od GIS video ;)
:rofl: :wink: :shrug: :pissed: :pissed: :notworthy: :notworthy: :D :oops: :D
<-----My avatar represents the state of my ST165 :(
rio_cyber
Postby Klas » Mon Dec 12, 2011 4:13 pm
Klas wrote:
alltracst185 wrote:Looks awesome bro! :D Now get a video of her purring ASAP! Again congrats!!!
Thanks!
A video will come, just have to order a new low temp thermostat (77C) from the US.
Discovered that my thermostat (82C) had really poor flow and didn open as much as I want (poor circulation).
I also need to fix a very small oil leak at the turbo inlet flange.
So, you have to wait a couple of weeks :wink:
Well, got my thermostat today. It´s a Gates racing thermostat that they claim fit the 3sgte. NOT :bangshead:
I drilled small holes in a 82 degrees thermostat and installed for now.
1/4 in 12.577s 176km/h so far
If you can turn, you drive to slow!
Now on youtube!
http://www.youtube.com/watch?v=hSD6LlwS830
Klas
Postby Hotrodhendrix » Mon Dec 12, 2011 9:38 pm
I bet her purr sounds something like "seeeeexxxxxy sexxxxxxxy seeeeeeexxxy sexxxxxxxxxxxy"
Postby dragstang86 » Tue Jan 31, 2012 5:02 pm
Was milling the ribs on the block the only thing you had to do to get it to work with the trans and transfer case? How far did you have to mill it? Mill the ribs down flush to the block? No holes needed to be drilled and tapped on the 98+ 5sfe block?
Did you build that exhaust manifold?
Build looks great btw!
92 All trac
dragstang86
Postby dragstang86 » Tue Jan 31, 2012 7:25 pm
Also about your main girdle. What material is that 3/16", 1/4". What main studs and oil pan bolts are you using with it? I assume you made that yourself? Does anybody sell those? If not I can draw one up and have it laser cut but either way I'd like to run one.
92 All trac
dragstang86
Postby Klas » Tue Jan 31, 2012 8:38 pm
it seems that the blocks from 98+ can be a little different. You have to mill or grind the ribs down completely And its important to assembly the clutch and transmission togetter when you check the clearance.
Regarding the threaded holes on the block, I had to drill and tap some holes to use the stock transfercase brackets. The bosses was already cast in the block (99 camery block) exept one I think.
The girdle was made of 1 inch thick piece of tool steel. I don´t remember what mainstuds I used exept it was ARP studs. I made the girdle myself, but I dont think you need one. I did one to prevent maincap walking, but I will aim for some serious hp numbers. I dont think you need a girdle under 700hp on these blocks. Just my 2 cents.
The exhaust manifold is a cheap chinease stainless manifold (100 bucks) with a homemade adapter. Will be making a new manifold next year.
Hope I have answered all your questions.
Allways fun to help.
Now on youtube!
Klas
Postby dragstang86 » Tue Jan 31, 2012 9:34 pm
What size turbo is that? I'm trying to figure out how big I can go without having to start relocating the radiator etc. Mine is a ST185 but I would think there is about the same amount or room between engine and radiator? I have a GT3582 that I just bought but I am starting to consider a 40 series.
92 All trac
dragstang86
Postby MWP » Wed Feb 01, 2012 12:29 am
Klas wrote:
alltracst185 wrote:just have to order a new low temp thermostat (77C) from the US.
Where are you getting that from?
I need one too :(
Postby Klas » Wed Feb 01, 2012 7:35 am
dragstang86 wrote:What size turbo is that? I'm trying to figure out how big I can go without having to start relocating the radiator etc. Mine is a ST185 but I would think there is about the same amount or room between engine and radiator? I have a GT3582 that I just bought but I am starting to consider a 40 series.
The turbo is a GT4094R. I had to make the adapter so the turbo sitting as far to the passangerside as possible, I had to move the clutch slavecylinder about an inch or so. The radiator had to be tilted about 2 inches forward in the top.
I think you will have to move stuff around even with a GT35.
Now on youtube!
Klas
Postby Klas » Wed Feb 01, 2012 7:39 am
I need one too :(
I bought the termostat on ebay, but it doesn´t fit our cars (much to big).
But if you find one that fit our cars, please let me know
Now on youtube!
Klas
Postby Hic » Wed Feb 01, 2012 9:11 am
buy one from the fensport :D:D:D:D
Hic
Postby Klas » Wed Feb 01, 2012 3:32 pm
Hic wrote:buy one from the fensport :D:D:D:D
:rofl: I don´t think so!
Now on youtube!
Klas
Postby sleeper » Fri Sep 28, 2012 2:25 pm
Hi.
So when are you going to get this car up and running? some friendly 1\4mile rivalry would be fun:-)
sleeper
Postby Klas » Fri Sep 28, 2012 5:42 pm
Long time ago!
well, the car just needs to be tuned, will probably do that next spring.
Have been renovating my house for a while now. = no time for the alltrac.
Probably gonna make a cage for it this winter, got a pipe bender and some pipes laying around.
Congrats on the great times on teh quarter mile sleeper!
Now on youtube!
Klas
Users browsing this forum: Baidu [Spider] and 3 guests
