celica_gtx
New member
Where's the mind blow smiley face?
:shrug: Never claimed to be an expert like you, but as usual you come into a post to demean without bringing data or trying to educate. I am in the process of learning, and trying to share what I learn. I think before doing too much to the car from a budget stand point it is better to research and collect data before having stuff built or bought. I have learned from previous mistakes. You may think me dramatic, but I am passionate about these cars and our community. I have seen a lot of members give up on these cars, and I would rather see more people racing them and winning.MWP":ackerbnr said:Yeeeeeah.
Thats just a big blurb by someone who knows obviously quite little about suspension setup.
Its all overly dramatic, as was your "big issues that holds our cars back in the racing world".
This is something I know, but the problem with this is there is not a lot of public data on what the actual is a proper ride height for the 185. It is very possible that stock ride height on a 185 is going to be the best from a geometry standpoint. That is how toyota designed it. The goal is the find out the best balance of ride height while maintaining the best geometry. Adrian's conclusion with keeping stock parts and his koni race shock inserts, 1" is the most he wanted to go. Martin on the other hand found he can go lower when making changes to the control arm and steering arm. TRD's lowering springs only brought the car down just over 3/4" so in that respect that may be a clue to Adrian's data being close. My car was lowered 1.9" vs the 1.3" tein suggests. Raising my car to teins recommended height changed the car dramatically (mostly due to more travel). There were claims in the past that there were no geometry problems unless you go more than 2" lower than stock, but without any hard data it was more internet speculation.MWP":ackerbnr said:Anyone that doesn't know that overly dropping ride height of a car leads to a heap of other geometry issues, is never going to have a properly competitive race car.
It doesn't just apply to GT4's, it applies to any car.
Here is a link to the instructions. http://www.longacreracing.com/technical ... ?item=8162MWP":ackerbnr said:I am looking forward to seeing the amounts you measure.
The tool looks interesting. I gather the dial gauge measures against the big plate as you move the suspension up/down?
If so, how does it account for change in the kingpin angle?
CMS-GT4":1d9tkgdh said::shrug: Never claimed to be an expert like you, but as usual you come into a post to demean without bringing data or trying to educate. I am in the process of learning, and trying to share what I learn. I think before doing too much to the car from a budget stand point it is better to research and collect data before having stuff built or bought. I have learned from previous mistakes. You may think me dramatic, but I am passionate about these cars and our community. I have seen a lot of members give up on these cars, and I would rather see more people racing them and winning.
CMS-GT4":1d9tkgdh said:This is something I know, but the problem with this is there is not a lot of public data on what the actual is a proper ride height for the 185. It is very possible that stock ride height on a 185 is going to be the best from a geometry standpoint. That is how toyota designed it. The goal is the find out the best balance of ride height while maintaining the best geometry. Adrian's conclusion with keeping stock parts and his koni race shock inserts, 1" is the most he wanted to go. Martin on the other hand found he can go lower when making changes to the control arm and steering arm. TRD's lowering springs only brought the car down just over 3/4" so in that respect that may be a clue to Adrian's data being close. My car was lowered 1.9" vs the 1.3" tein suggests. Raising my car to teins recommended height changed the car dramatically (mostly due to more travel). There were claims in the past that there were no geometry problems unless you go more than 2" lower than stock, but without any hard data it was more internet speculation.
CMS-GT4":1d9tkgdh said:Here is a link to the instructions. http://www.longacreracing.com/technical ... ?item=8162
You angle the the roller and dial against the plate. You jack the suspension from the chosen ride height through your range of travel and take readings. I can not answer your 2nd question because I have more to read up before I gather my data. I also want to take some of my own measurements before doing so to get an idea of my roll center etc.. I think this will all be more involved than just using this gauge, but this gauge will give me some ideas about how much toe change I have in various conditions. And like I said, it may not be a big issue at all, and its possible that if there is it could be a simple fix. Hopefully we can all learn something from this, and people can use the data to approach their own setups. But of course there is enough variance car to car that my exact changes may not be the solution for everyone and each individual who wants to make these sort of changes is best off measuring themselves. The same amount of shims etc.. I may use may not be the same for another 185.
CMS-GT4":2h2po2w6 said:I need to read up and see what needs to be disconnected if anything. I need to remove the springs from the stock struts before I take the readings as well. As I understand it the toe will change linear with the movement of the suspension. So what I am looking at is likely finding the balance between the full travel and minimum bump. I am hoping the tierod flip is ultimately the solution, but if not I will be looking at measuring the pivot point from the steering arm.
CMS-GT4":2h2po2w6 said:Here is a video I found before buying the gauge where an rx7 measures. You can see the toe change in one part. https://www.youtube.com/watch?v=Stp9kHAGfXQ
In other news I had been in contact with Jvab on a building a bilstein suspension for these cars. I had never heard of him before someone suggested him to me on youtube. From what I have gathered he is some sort of bilstein wizard. He mostly makes gravel setups for rally but can make me a street track setup. He does not do adjustable setups. He claims he builds it right and it does not need adjustment for the end user to screw up settings. His stuff isn't cheap though, of course. 2200 for 40mm, 2400 for 50mm. He suggests I run 50mm front and 40mm rear. His top hats are $200 more. He has built for a 185 before.
CSAlltrac":2qwcsudv said:I understand the desire to make your car everything you want it and more. What I dont understand is what an extreme suspension setup is needed for. From what I have seen you drive your car about as much as I drive mine....hardly at all. So why try and modify it to where its on a competitive level, one thats on the same level as one of the WRC cars were. Or any one of the other fully race prepped and factory backed machines you used as an example.
CMS-GT4":2z96cmmv said:I found this today. No idea how legit it is, but it is an interesting read on a person rebuilding their own BC shocks into something better.
http://www.clublexus.com/forums/gs-firs ... 1-3-a.html
MWP":1h2s6ccw said:I sense the frustration of trying to pick the best option is starting to kick in :bangshead:
Its one of the most important parts of the car to choose/tune, but it is also the most difficult to do so without a mech eng degree and/or shock rebuild workshop.
It really is a problem when you want to find an option thats better than the common $1k coilover kit, but don't have the $$s to spend on development & re-shimming to get something better.
