bloodMoney
Active member
Would you be selling those 050s then?
I have always liked those....
CMS-GT4":2vhc1tsr said:I broke a bolt that holds the headlight. I run 38 et all around but I have a 25mm spacer in the rear.
That's also the bolt I broke back in the day, ended up drilling it out, welded a washer right there to the metal, and put new screw super tight in there, well, also bcuz my body/frame was screwed over there and had to raise the whole assembly one corner with that washer..lol.. was a total jimmyjob fix.. lolCMS-GT4":21oy4hvl said:I broke a bolt that holds the headlight. I run 38 et all around but I have a 25mm spacer in the rear.
