I am trying to decide on a gauge to monitor my car. I was looking at EGT but I mostly just want to make sure I am not running lean or anything. I might see if a local has a wideband they might let me barrow so I can get some intial readings and make sure I am content with how everything is running before turning up the boost.
I have quite a list of things to sort out once the car is back. I need to put the interior back in. Before I can put in the dash, I need to wire up the new radio, the AC system and boost controller. I think I am going to wire up the water level sensor on the AC just because if some reason I ever got a leak in the system I would rather the car told me. As of right now, I check the water levels before I ever go for a drive. I also need to put in new door speakers.
I guess those are the priority items for now. After that, I want to do my brakes, then place some sound proofing in the trunk and make a flat fiber glass panel so I can have a normal storage area back there. I may even put a new like the 350z has back there.
