Active member
Well it seems that I am done with the engine. I moved my MAP sensor, installed new plugs and new wires and installed the IC.
Turns out my old "pregapped" plugs were gaped to ~040. Should have been ~032.
Here is a pic of the old plug. Lots of carbon, and the tip is white. Use a cheap set of plugs when setting you car up, then once its done get new or better plugs.
Here is the engine bay. I think I ma pretty much done. I do not plan on taking this apart any time soon. If all goes well, I will have the driver side axle done tomorrow then the car is ready for paint.
The car is more responsive now, and even though it still seems slightly over geared, its not near as gutless as it was in the mid range.
