So it looks like I am to my stopping point with the car for a while. I have a couple small things to do like adjust the fender line I welded up to prevent rubbing, a new cotter pin on one caliper to make it quieter and then just a spot inspection after some more drives to see how ever thing is holding up. I also need to drop it off for an alignment next week. But now that I am caught up, I won't be messing with too much car stuff for a while. I'll still post around some, but my focus now has to be my career and skill set. I will try and post here to update on the shirts I am doing, but if you just add Noritoy to your favorite ebay sellers you should get some sort of notification once I list stuff. I plan on doing one gathering with Mark and maybe some of the other locals but other than that the car will just get some short drives here and there.
Mods to date:
St205 engine and intercooler with upgraded heat exchanger
ford racing intercooler pump
greddy profb spec2
3" turbo back exhaust to a Sard MIG catback
custom K&N intake
RC gearbox
St205 rear torsen LSD
Super pro suspension bushings
Whiteline rear sway bar
whiteline f/r stut bars
Racing beat adj endlinks
tein HA coilovers
Mario Konig Rear solid LSD mount
Cusco Chasis underbrace
front 5x114 conversion
rear 25mm spacers
(Summer) sportmax 050 17x9 /(winter) ADR Fuel
st205 rear calipers and brakes
BFG braided lines front Revolution rear lines
Custom wilwood BBK with 2 piece rotors
Short shifter
Autometer boost and water temp in custom column pod
RC Hood and Bumper
Pearl Black toyota emblem
HKS Turbo timer
Momo Shift knob and Steering wheel
Battery relocated the trunk
ASI Aluminum radiator
JVC headunit with Kicker subs in the doors
Gt Silver Metallic paint.
RC Hood and bumper
JDM front corner lights
walboro 255 pump
braided clutch line
extended slave cylinder rod
shifter bushings
short antenna
I am sure there are other odds and ends I might have left out, but that is a majority of the parts dropped in this car.
Here are the latest pics. Its cold again, but at least the weather is nice.
