Project CMS
Postby CMS-GT4 » Fri Mar 23, 2007 10:53 pm
I went with the 205 pump cause it was newer and my 185 pump had a bent pulley.
Its leaking where the hardlines go in. I am not sure how I am going to fit my hands in there to tighten it but I am going to try this weekend.
I am trying to find my tein height adjustment tool. I need to lower one corner to match the car so I can taked it in for an alignment.
Guess I should list my mods as well.
1992 st185
RC hood and bumper
JDM clear corners
hks turbo timer
ae92 short shift lever
razzo weighted shift knob
speed source shifter bushings 1.0 & 2.0
RC gearbox
st205 engine
whiteline rear swaybar
tein HA coilovers
konig solid diff mount
some of the super pro bushings
25mm rear spacer
17x9 sportmax 050 wheels
255/40/17 tires
3" dp, midpipe
sard 2.5" catback
custom straight intake
aluminum a/m charge cooler, cobra IC pump
removed charcoal/ cruise/ rear seat
Things to do before the meet:
Fix alignment
change rear diff fluid and verify lsd (sell extra lsd)
install: interior, emanage, remaining super pro bushings, whiteline strut bars, ebc, dp bracket, 255 fuel pump, momo knob
double check vac hoses
get guage pod
Extended plan: paint, better clutch, tune emanage, steering wheel and maybe a new solution for the ps pump.
Postby 1990CelicaGT-S » Wed Mar 28, 2007 1:00 pm
Nice list. I noticed you had a Razzo weighted shift knob...how does that affect shifting?
Also, how did you go about removing your cruise control?
1990 GT-S - (May be ressurected as the DD)
1990 GT - Parting out
1990CelicaGT-S
Postby CMS-GT4 » Wed Mar 28, 2007 1:09 pm
I pulled out the control box and the mechinism under the engine bay.
I am sure their is more to it, but I might end up wanting to put it back in, depending how much I use this car.
I am not going to bother with the powersteering for now. I am just going to start working out more.
If it does not rain tonight, I am going to roll my fenders and adjust the height of my coilovers. I may try an install my remaining bushings. Then I send the car off to the alignment shop. Going for a mostly stock alignment with 2 degrees of camber in the front.
Next chore is chainging the diff fluid and verifying my lsd.
The weighted knob is much like the stock knob. I didn't realise how much the stock knob was weighted till Ibought the razzo one. I like the shape of the razzo. It much like stock as well.
Postby CMS-GT4 » Thu Mar 29, 2007 4:51 pm
Rolled the rear fenders this morning.
Here are some pics.
The rear suspension is so stiff, that I had to push the car pretty hard to get it to rub. I wanted to remove the chances of more rub.
I also added enough pressure to the roller, to flare the fenders lightly. Looks like I have some flex room on the backs now if I wanted to ever go wider on the tires.
I need to finish a spot on the rear driver side then the rear is done. I didn't bother using a heat gun since I am getting the car painted anyway.
I would suggest using one if you want to save your paint though.
I am going to attempt to do the fronts as well. They are already rolled from the factory but I want to try and flare them just slightly. I have a little bit of rub on the right side in the front. Adjusting the height might help that some, but I want to make some room to add my 8mm spacer in the front.
I also drained the rear diff. It passed the turning lsd test, but I can not see in there well enough with a flashlight. So I am going to go rent a scope or something. I hope there is an lsd in there cause I don't have time to install one right now. I am going to have to start spending so much time on the car and get back to the business.
Before
Roller
After. This shows how much clearance there is now. Still not a whole lot.
Comparisons to the inner llip of the fender.
Postby turbo4wd » Thu Mar 29, 2007 4:57 pm
Hmm.. I was thinking about buying a fender roller..
I have the problem in the rear where the tires will rub against that litle part of the fender and leave a gummy residue..
Dan
Undercover Moderator
turbo4wd
Postby CMS-GT4 » Fri Mar 30, 2007 3:19 pm
The roller was much harder to use on the front. I gained a few more mm of clearance though for those really hard turns.
I have so many projects going right now, I think I might hold off on some of my mods till later.
I have to get my print shop up asap and work on my online store.
So I am going to sort out my idle issue, set my suspension height and get an alignment. I will either send it in to get the rear lsd installed or do it myself in a month or two. I still need to bleed the brakes and put some better fluid in.
Postby CMS-GT4 » Mon Apr 02, 2007 2:58 am
Tried filling the fluid in the rear tiff to get me by till I can take it to a shop and have them replace it with the torsen.
I need to add another thing thing on my list as reason I need to kick mister toyota n the balls.
I tried a few things, Put a bendy drinking straw on the end of the diff oil contatiner. It helped. Ended up messing the bottle up trying to come up with a faster method.
I picked up a oil pump for running fluids into tight places. So I should be able to finish that this week, then send it in.
I just have to figure out if there ar any clips or parts that I need to get for swapping a torsen into an opened diff.
I might have to reedit this in the morning, my sleeping pill started kikcing in before I started typing this.
I will most likely not be messing with the car till the end of the week. I need to double check some vac hoses, then fill the rear diff. Then I am going to adjust the height and take it to a shop to install the rear lsd. After that it gets an alignment. That might be all it gets before the dragon meet, just cause I have so much going on with the online store and the print shop. I had planned on being ready so I could do dragon shirts in time, but those just won't happen this year.
I was sort of happy that the rear lsd was open. I hope this leads to more handling potential to the alltrac.
I have been realy busy with the printshop, since its my priority.
I hope to have the shop operational this next week then I have a large project with an art print contest I held. Mostly trying to get my main projects done and slowly finish the alltrac.
It might take a few more months, but I want it done right.
Postby smog7 » Mon Apr 02, 2007 3:08 am
rolled fenders! thats awesome. did you just roll the top of the fender or the whole thing? *Edit* also is this the type of pump you used? Im going to be changing out the fluids on my car soon and I need to source one of these.
-omar
rally tarmac 1990 st185
smog7
Postby CMS-GT4 » Mon Apr 02, 2007 3:26 am
No, the pump I got looks like a mini basketball pump but its setup for fluids.
I rolled the majority of the fenders. The machine could not do the bottoms. I figuredI would just blend it and leave the bottoms so I can easily rinse out dirt.
Postby CMS-GT4 » Fri Apr 06, 2007 9:31 pm
Alright. Here's an update.
I made a final list of things I am doing before the meet, then I am going to slow down a little on the car.
I adjusted my Teins today to the specs in the HA sheet. I sort of want to make the fronts a little lower. To their specs the rears are lower.
I also sorted out my high idle issue.
I plugged in the a/c vsv and it fixed the rev issue. I am going to test drive it again. I need to examine my lines for the turbo vsv. I also need to hook up my boost controller. I am going to finish my suspension height this week, then get my lsd installed, then the alignment.
Here is the new idle vid.
http://s127.photobucket.com/albums/p136 ... I_4852.flv
Here are some pics of the alignment to Tein's specs.
Postby smog7 » Fri Apr 06, 2007 9:37 pm
looking very good
-omar
smog7
Postby C-dubb » Fri Apr 06, 2007 10:13 pm
Looking good. Glad to hear you're getting a lot of the bugs worked out. What size and offset are your wheels? spacers? They look great.
Cory Wilson 1990 st185
C-dubb
Postby CMS-GT4 » Fri Apr 06, 2007 10:54 pm
Thanks.
17x9 38et 255/40/17.
I just took it for a ride. After lowering the front an additional 15mm (5mm lower than the rear) And it handles even better. Maybe its just how I like thecar to feel or something, but the front is so much better. The whole car is better since I lowered it more.
I just installed the whiteline front strut bar. It barely clears the 205 catch can. Clears the IC just fine. I have been driving around with no strut bars at all (even oem).
I am going to see if I can tell anything different from just a front bar. I will install the rear bar in the morning and compare, and if I have time, I might install the oem body brace. I was wanting to paint it first before installing it. I might do that in the morning as well.
Postby CMS-GT4 » Fri Apr 06, 2007 11:12 pm
Just for the hell of it, I wanted to PS a savage lip on just to see how it would look.
Postby C-dubb » Sat Apr 07, 2007 4:54 pm
CMS-GT4 wrote:Just for the hell of it, I wanted to PS a savage lip on just to see how it would look.
I Have been thinking about adding a lower lip to the RC bumper when i get it put on properly. Did you PS and see how it looks from the front View?
C-dubb
