Project CMS
Re: Project CMS: st205 swapped grip machine
Postby Hotrodhendrix » Fri May 17, 2013 12:23 pm
CMS-GT4 wrote:My wife helped me do a shoot and I put this together for fun.
Gentlemen, we can rebuild him.
We have the technology.
We have the capability
Better... stronger... faster.
Haha cool pic
Postby underscore » Fri May 17, 2013 8:37 pm
Awesome shot!
Postby CMS-GT4 » Mon May 20, 2013 3:13 am
Thanks. I actually did some more work to it. I think I'll post the revised version to my DA account.
http://noritoy.deviantart.com/art/Gtfou ... -372689813
I am revisiting my battery relocation. I ground to the chassis, but not to the engine. I am thinking of running an additional ground.
I currently run two big bolts through the rear floor pan to hold my metal tray down. I did not think of using anchor bolts like the stock one does. I am going to look into some short j hook bolts and likely move my battery to a location to maximizes my space in the trunk and lets me remove it as well.
http://www.iwsti.com/forums/how-install ... trunk.html
Postby underscore » Sun May 26, 2013 2:20 pm
I don't think there's much point in running another ground back to the engine bay, I mean the entire body is a ground after all.
Postby SkagTits165 » Sun May 26, 2013 9:39 pm
it is a good idea to run a wire between the block and the negative terminal, as the return path for the spark/ignition circuit is much better achieved through a direct copper path, as opposed to a steel path, with many contact points
SkagTits165
Postby CMS-GT4 » Tue Jun 04, 2013 5:44 pm
From what I have read starting is better with the ground to engine. I know once I added several ground to the engine the car ran considerably better, so I think there is something to this. Right now I am just going to get my charging array setup, I will extend the ground later on. I will likely just run two on the chassis for now.
I found my future wheel if they make proper offsets and widths in 17s.
http://www.ssr-wheels.com/wheels/gtf01.asp
Postby warracer » Wed Jun 05, 2013 1:06 am
Wow awesome wheels! Your project is going really well keep up the good work :D
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby CMS-GT4 » Wed Jun 05, 2013 3:10 am
Thanks. I am starting to do a few things to it before I get too busy and it gets too hot. I was looking at the Sard exhaust and I think I can remove the silencer mechanism. Its held on by 3 bolts in the exhaust tip. I am curious how it will drive with the device removed and how much louder it will be.
I also noticed apexi makes a similar silencer. http://www.ebay.com.au/itm/APEXI-ACTIVE ... 0816634219
Postby CMS-GT4 » Thu Jun 13, 2013 2:18 am
I removed the Sard's silencer last night. Before doing so I got video so there is a sound comparison before and after.
The outlet was usually 1.4" unless under heavy load. The tip is 3.8." I think the silencer was too restrictive. Now that its gone I am going to adjust my boost controller.
Video of the comparison.
http://www.youtube.com/watch?v=GGti7U2P ... e=youtu.be
Camera setup.
Fully extended tip.
The silencer.
Postby athousandleaves » Fri Jun 14, 2013 1:36 pm
I bet you could tune that silencer a bit by cutting some coils from that spring that keeps it shut...
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby underscore » Fri Jun 14, 2013 2:31 pm
Probably easier said than done by the looks of it.
Postby CMS-GT4 » Fri Jun 14, 2013 3:18 pm
I'm just going to leave it out. Its not worth the trouble, and the exhaust is not so loud that its a problem.
Postby athousandleaves » Fri Jun 14, 2013 10:20 pm
Are you still using the stock midpipe?
1992 White turbo4WD
athousandleaves
Postby CMS-GT4 » Fri Jun 14, 2013 10:26 pm
No, I have a 3" turbo back dp, and mid pipe. The sard system is 2.5"
Postby CMS-GT4 » Thu Jun 20, 2013 4:29 am
Tonight I converted my banjo bolts on my rear 205 calipers to direct adapters using earl's fittings. PN: 592032ERL
I just removed the banjo fitting from my line and now the line goes directly to the caliper. It fits a bit better now too in the rear. I bled the whole system, and the brakes are nice and progressive again as well as constant. Now I am waiting on my extended ball joints, then I can do my alignment. I am working up a todo list, and I will start slowly checking things off.
