Project CMS
Postby darthripley » Mon Jun 16, 2008 3:42 am
gauges seemed to dim when you revved it, other than that i didn't notice anything out of the ordinary.
weird it just started again like that ... did the rust gunk have anything to do with it?
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby CMS-GT4 » Mon Jun 16, 2008 3:48 am
Nope. I had not even gotten to do the flush yet. It just started. The reason the lights would dim, is cause the car would almost die once the rev started dropping past idle.
Postby Kcman91gts » Mon Jun 16, 2008 4:39 am
Holy crap that shit is disgusting i would definatly get on a coolant flush just incase , and i was thinkin the same how it almost looks like that orange sealant stuff ... very odd ..
Kcman91gts
Postby Sifu » Mon Jun 16, 2008 5:20 am
Could it be the weather? I know my MR2 doesn't like hot weather...
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby CMS-GT4 » Mon Jun 16, 2008 3:56 pm
And again, in the this time in the blazing heat, it starts again.
I might have feeling about what has been wrong this whole time, but I am not going to post it till I am sure. I will be pretty pissed off, if I am right.
Postby etantshi » Mon Jun 16, 2008 4:39 pm
At least throw us a bone.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby CMS-GT4 » Mon Jun 16, 2008 4:59 pm
A clip is broken on the wire that goes to the distributor cap. So it is pressed in there. Before I started it yesterday, I pressed it hard to maybe help the connection. It starts right away ever since. I have a feeling the broken clip kept it from getting a good connection. So now I am trying to find part numbers for either the whole wire or just the clip.
This could have been the issue the whole time....
Postby turbo4wd » Mon Jun 16, 2008 5:19 pm
CMS-GT4 wrote:This could have been the issue the whole time....
If thats what it truly is.. (and I'm hoping thats what it is)
You better jump for joy rather than be pissed.. because it could be a LOT worse.. Lets just cross our fingers and hope thats all it really was..
and then make plans for another meet! :D
Dan
Undercover Moderator
turbo4wd
Postby etantshi » Mon Jun 16, 2008 5:55 pm
So the high tension cord wire? That should be an easy fix.
André B.
etantshi
Postby CMS-GT4 » Mon Jun 16, 2008 6:19 pm
So I ordered a new cap for the distributor wire.
It starts every time now.
I wasted a few months over this simple issue. At least I figured it out. I was on the verge of selling the car, cause it takes too much of my time and wasn't running.
So once the cap gets here, I am going to doing some extra grounding wires, then it should be done.
Then its off to be painted.
Postby CMS-GT4 » Thu Jun 19, 2008 9:29 pm
So far today, I cleaned out all the cobwebs... literally.
Made another bracket for m heat exchanger. I will need a better bracket and to adjust the height of its location, but this works for now.
I also started putting things back on, and reinstalling things I took out.
I also removed all the gunk from the coolant filler tank.
After dinner, I am going to try and do a final flush of the coolant system.
Postby vip09 » Thu Jun 19, 2008 10:55 pm
I really hope that was your problem! Good luck with getting the rest of the car finished.
vip09
Postby CMS-GT4 » Thu Jun 19, 2008 11:23 pm
Thanks. It starts every time now after I pressed the plug tight. Now I just wait on the damn clip so I can drive with it.
I just did a big system flush. I am running water in it till I flush it again after a few days.
Done for the day. I will pick up and do more tomorrow.
Postby BriinumsBo » Fri Jun 20, 2008 7:04 am
congrats! :) good luck to get it ready while the summer is here!
BriinumsBo
Postby etantshi » Fri Jun 20, 2008 7:39 am
Victory! Tape it up and drive it around!
André B.
etantshi
