Project CMS
Postby CMS-GT4 » Thu May 10, 2007 8:53 pm
So I found a big vac leak. The 185 hose was a bit larger than the 205 fitting. I fixed it. The car runs better and does not pull timing as bad at the boost limit. I ordered a new boost gauge today as well. Once I get my vac reference I am going to go back through all the lines and see if vac is my entire issue.
Postby CMS-GT4 » Sun May 13, 2007 12:01 am
Got the new boost gauge in today. Turns out, I run 15-17psi. It pulls timing at 17psi, kicks it back down to 15 psi and hold it down to 10psi after running it hard for a bit. After fixing the one leak it does not pull timing as hard, but still does.
I think the 15psi explains why the car is so damn quick. Would have been nicer if it was that quick at 5psi though. :P
My vac is low though. So I suspect a leak is my issue.
Postby donteatbugs » Fri May 18, 2007 12:58 am
i just fixed a vacuum leak on mine. it was the power steering booster valve. i had major idle problems. the hoses were swollen pretty bad and popped off around 15 psi. my car wouldnt hold idle and would stall and the boost gauge read 5 in mh where it normaly reads 19 or 20.
donteatbugs
Postby CMS-GT4 » Fri Jun 01, 2007 2:14 am
Have not had time to touch the car. Been working a lot and trying to get my business off the ground. Plus I have had not luck trying to get 3rd gen vac resources.
Anyhow. I found this on my computer.
A vid of when I first got my alltrac.
As I said... it was perfect. Such a shame.
http://s127.photobucket.com/albums/p136 ... racvi2.flv
And a vid of when I first instlled the Teins, new wheels and my paint still looked good.
Notice how the sard exhaust sounds on a stock 2nd gn 3sgte vs the 3rd gen.
http://s127.photobucket.com/albums/p136 ... I_0570.flv
Postby smog7 » Fri Jun 01, 2007 4:57 pm
yay for understeer
-omar
rally tarmac 1990 st185
smog7
Postby CMS-GT4 » Fri Jun 01, 2007 5:00 pm
You should hear it now. Not a peep from my new setup.
Postby mike325ci » Wed Jun 13, 2007 5:58 pm
that was an enjoyable read... :) thanks for the story...
setting goals is a good idea, else the project becomes a bottomless money pit... as much as i'd like to make my car something crazy, i know it makes sense for my time and budget and what i want out of the car to keep it pretty much stock and just do a restoration/recondition on it... i don't want to say "here was my car back then, what a shame..." i have other toys that i can hack up, luckily... ;)
anyway, there are some interesting threads here in this subforum! maybe i'll start one myself...
OH, btw-- i ran across this thread b/c i was doing a search on LSD. you put in a TRD torsen? i'm gonna have to "check" mine and see what my options are. continuing on to my forum search results....
NYC, NY, USA
mike325ci
Postby CMS-GT4 » Thu Jun 14, 2007 5:39 pm
Have not had much time to fool with the car lately. Lot of work on the biz, family, sick dog, work etc...
I keep getting the wrong size cap at Home Depot. I am taking an intake pipe with me this time. I plan on testing for vac leaks very soon.
Postby CMS-GT4 » Fri Jun 15, 2007 2:32 pm
So I went to a plubing shop and purchased a plastic cap w/ 3" inner dia. Then I instaled a fitting that will connet it to my air compressor. I then ran ~20-25psi into the straight intake.
I found 2 things leaking air. My a/c ice vsv, which I already knew about. So I replaced it.
Then I found my oem oil catch can has a massive crack in it that is spewing out air. Which explains my vac/boost issues. At least I think so.
So if anyone knows where I can get a oem catch can cheap sent to me in the State, I would appreicate it.
Postby illGT4 » Sun Jun 17, 2007 12:28 am
CMS-GT4 wrote:So if anyone knows where I can get a oem catch can cheap sent to me in the State, I would appreicate it.
Does it need to be OE?
Imagewww.illtuned.com
- Vehicle Dynamics Specialist
illGT4
Postby CMS-GT4 » Sun Jun 17, 2007 1:03 am
I got a guy from the UK sending me an oem one for the cost of shipping. So, I am set now.
I just put some silicone on the crack of the old one. I want to stop the leaking enough to do more leak testing to make sure thats my last leak.
That way I don't have to wait for something else, after the new one comes.
Postby CMS-GT4 » Sun Jun 17, 2007 2:16 pm
So I siliconed and taped up the cracks on the catch can so I could test for more leaks. I found another big one right on the turbo. The clamp on the hose that connects the turbo to intercooler is broke. So I replaced it and went for a test drive.
Idle was better, however after letting off the gas I still get a dip in idle.
Vac is around 17 at idle and goes to ~25 while coasting.
THe car drives good. It only boosts 15psi now instead of 17.
The timing also does not pull near as hard, if at all.
I think I sitll have vac gremlins somewhere but I think I got all the leaks covered. Just a matter of figuring out what hose is hooked up wrong.
Postby illGT4 » Sun Jun 17, 2007 2:22 pm
Good to hear things are going better for your project. :)
illGT4
Postby CMS-GT4 » Sun Jun 17, 2007 6:14 pm
I think I just need a 3rd gen vac reference then I can double check everything and finish my issues.
Postby etantshi » Sun Jun 17, 2007 6:23 pm
Time will tell if the LSD vs non LSD will be as dramatic a difference as you have experienced. I hope it is. Thanks for the LSD josh, good luck on your vac problems.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
