1990 st185-300whp +++
Re: Project: Get your shit together-Head rebuild update
Postby MWP » Wed May 04, 2011 12:21 am
Our engines dont have "lifters", what you are talking about are buckets :P
They will be about 2/3rds the weight.
Postby toayoztan » Wed May 04, 2011 4:41 am
MWP wrote:Our engines dont have "lifters", what you are talking about are buckets :P
Hah, didn't even catch that.
Yeah, definitely are lighter.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby C-dubb » Wed May 04, 2011 2:40 pm
They are still technically lifters, it refers to their function in the valve train. Not just which direction they lift or that they are shaped like a bucket.
Actually when I ordered the parts they are catalogued as "Lifter, valve"
Cory Wilson 1990 st185
C-dubb
Postby C-dubb » Tue May 10, 2011 1:10 am
So, pretty bored tonight and thought I would go through and post the up to date mod's and plans for the car.
I have all these parts lying around waiting to go back on the engine/in the car...the head needs to hurry up and get donededed.
Aeromotive FPR and fuel lines
3" exhaust system...with one of the muffler tips dented during shipping :x
So heres the updated list of parts and such on the build thus far:
Engine:
-JE pistons 9:1 CR (have to check the bore, but I'm pretty they're .020" over from factory bore)
-Eagle H-beam rods
-ARP main & head studs
-MLS head gasket (need a new one have to measure the old one but i'm pretty sure with that compression ratio it was rather thick)
-All balanced and blueprinted when rebuilt
Cylinder head (Being built):
-Ferrea dual valve springs
-Shimless "bucket" conversion
-GSC 268 cams i/e
-ATS adjustable cam gears
(They do a port and polish for a pretty minimal price, debating having them do it for me)
Fuel system:
-Wolfkatz sidefeed fuel rail
-Supra TT 550cc injectors
-Walbro 255lph fuel pump
-Aeromotive adjustable FPR
-awesome OEM fuel filter
Engine management:
-AEM EMS
-AEM UEGO
Turbo:
-KO racing Street Brawler T3/T4 50trim .63 A/R
-Sweet Turbo XS MBC (anodized blue :smokes: )
-FMIC setup
-Turbo XS RFL BOV
Drivetrain:
-ACT 6 puck cluctch (unsprung)
-Solid shifter bushings
Suspension:
-GAB adjustables and lowering springs (rear)
-Lowering springs (front)
-SS Adjustable swaybar endlinks
Other mods/changes:
3" straight intake, Full 3" exhaust, AC delete, EGR delete, Charcoal canister delete, ATS knock sensor, no more crappy AFM
Also, working on sourcing a 3sge sidefeed manifold (found a couple out of state)
The head should be done in the next couple of weeks and should be able to get it back together and rolling within a couple of days after I get it back.
C-dubb
Postby C-dubb » Thu May 12, 2011 1:59 am
Finally took a picture of the car in it's re assembled form. Kinda dirty needs
C-dubb
Postby GT4times2 » Thu May 12, 2011 4:24 am
Looks great!!
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby CMS-GT4 » Thu May 12, 2011 4:58 am
Looking good.
Postby toayoztan » Thu May 12, 2011 5:49 am
Looks good, I like the stance with the wheels.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby C-dubb » Thu May 12, 2011 4:15 pm
Thanks guys. The trim piece on the headlight is missing...misplaced it when I moved. Need to find it and replace it. Also, need to find a new carbon fiber trim piece above the bumper cover...the replacement I bought on ebay broke during shipping.
I like the wheels but I'm thinking about getting a little bit taller tires all around to fill in the wheel wells...I don't like how low profile those tires are, especially on an 18" wheel.
C-dubb
Postby Balagast » Thu May 12, 2011 4:56 pm
Very nice work.
What exhaust did you get there? I'm curious about what people are doing for mid-pipes, being as I need to replace the stock one in my trac (damn rust).
1990 All Trac - Red (Down but hopefully not out)
Balagast
Postby C-dubb » Fri May 13, 2011 1:18 am
I found it on ebay...I'm pretty sure it's the ssautochrome exhaust, I bought it from a different seller though. It was the only 3" exhaust I could get in short order. They are few and far between so I bought it as soon as I saw it listed.
There are a few different topic floating around the board right now about people building midpipes so there may be some available soon.
C-dubb
Postby C-dubb » Sat May 28, 2011 8:47 pm
New parts came...dropped them off at the machine shop and the head is closer to being finished.
New Cams
New Gauges
I also ordered a 3sge intake manifold from what they told me was a 1987...either it wasnt or it was just a non T-vis one but they sent me the wrong manifold. I'm glad you can't ask these part salvage people any questions without them saying "Well, is it for a 3sge?" Yeah Idiot I'm not gonna try to explain to you the dynamics of interchangable parts within the same engine manufacturers...too complicated
Not that T-vis matters or that you know what it is...god. I may just stick with the stock 3sgte manifold...but then again I don't want to try to explain to the Tuner that there are lean cylinders that need to be compensated for...because I'm just an Idiot who can't tune his own engine...
C-dubb
Re: Project: Get your shit together-New pics of Car and parts!
Postby alltracst185 » Sat May 28, 2011 10:21 pm
Looking good bro, keep up the good work :)
alltracst185
Postby DudeMan » Sun May 29, 2011 12:08 am
Can't pull the manifold at a wrecker yourself? Would save some trouble..
I might have a 3SGE manifold for sale soon. Its already ported to match the TVIS plate and I plan on sandblasting it soon, should look like new.
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby C-dubb » Sun May 29, 2011 12:24 am
I haven't been able to find one at any local yards...I'll take it if you wanna sell it.
C-dubb
Users browsing this forum: Yahoo [Bot] and 2 guests
