Sex change: 1990 GTS converting to Alltrac.
Postby celicaGTS_T » Fri Apr 27, 2007 3:54 am
Well, the title says it all. I plan on taking my GTS and turning it into a full-on Alltrac. A buddy of mine has all of the parts for it (driveshaft, rear subframe/ suspension, gas tank, engine/ ecu yada yada yada... ). I know, it sounds a little far-fetched, but he wants to try the conversion out. I'll keep you guys informed on how it happens.
-Justin
celicaGTS_T
Postby theUNYTEDone » Fri Apr 27, 2007 9:13 am
good luck with that.
why not go the full 9 and get a chassis too? :oops:
jk man. hope all goes well. keep up with the updates.
was he THAT set against just getting an alltrac?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby CMS-GT4 » Fri Apr 27, 2007 2:09 pm
JMHO,
If I was going through the trouble of adding a who new rear subframe, I would not make an awd car.
I would be making it into a rwd monster. You might be happier with a rwd car anyhow.
Postby celicaGTS_T » Sat Apr 28, 2007 2:41 am
Well, my buddy 'imports' jdm clips and full cars. He has about 3 or 4 clips for the alltracs and a couple RC's at his shop w/ all of the rear goodies, iirc. Thats why I thoght it might be a neat idea. Keep you guys updated.
-Justin
celicaGTS_T
Postby ___Scott___ » Sat Apr 28, 2007 3:49 am
Take lots of pics and post the the progress.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby GT4RC » Sat Apr 28, 2007 6:31 am
CMS-GT4 wrote:JMHO,
+1, the only real glory of doing this is to have one of the few fully converted 4wd celicas, but in the end you have a factory option. Why not have an end result thats totally different than what you could just purchase with a higher trim level? We wanna see more celica smoke shows!!!
Had to say it man, either way my hat is off to you if you complete it.
GT4RC
Postby theUNYTEDone » Sat Apr 28, 2007 6:08 pm
so how much to send one over to hawaii? :evil:
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby 90 all trac » Sat Apr 28, 2007 6:57 pm
I'd only do this to a st204, def not to a st184
88 st165 - in pieces
70 240z - l28et, SDS, lsd
90 st185 - sold
90 all trac
Postby celicaGTS_T » Sun Apr 29, 2007 12:42 am
Well the RC clips alone are $2300 and the standard Alltracs are somewhere around $2000. He hasn't told me the going rate for the full conversion. The rwd conversion to me seems a little harder then the 4wd conversion, but I could be wrong. I'll take pictures if I get the chance, but money is needed and unemployment blows. Wish me luck.
-Justin
celicaGTS_T
