Home of the 10 Sec/210 mph mile AllTrac
Re: Home of the 10 Sec/210 mph mile AllTrac
Postby CSAlltrac » Fri Oct 04, 2013 2:10 am
+38
Postby aus jd 2703 » Tue Dec 03, 2013 9:38 pm
pat what seats and rails are you running?
looking into seat options for my car
aus jd 2703
Postby alltrac101 » Wed Dec 04, 2013 12:33 am
I run 2 Sparco Pro2000 with the Sparco vertical brackets. Pass side is fixed to a custom SS rail while the drivers is on a slider fixed to another ss rail...drivers side has only 2" of slide because of the roll bar
alltrac101
Postby aus jd 2703 » Wed Dec 04, 2013 12:53 am
Did you have to off set the seat to one side or remove door trims for it to fit with out hitting the door/window? I have been told your seat shouldn't fit so i am curious if you had to do any modifications? Thanks
aus jd 2703
Postby alltrac101 » Wed Dec 04, 2013 12:45 pm
No trim mods, I mocked them up so I wouldn't have to cut the door cards, it's close tho, 1/2" on the DS, the PS is 1 1/2"....The difference is because of where the steering column is located...DS centered on the coulmn.
alltrac101
Postby ALLensTRAC » Thu Apr 10, 2014 8:50 pm
Hey Pat I know that you don't frequent here as often but I have a question I believe you are the only one who can answer. What clearance do you have for your front brakes with the 18x9.5+38 RPF1's? Could you run 355mm rotors and do you have some inner barrel pics or spoke to caliper pics I could look at? I am ready to order wheels but they are special order in SBC and I need some clearance questions answered for my 355mm rotors. Thank you in advance for any help or advice you can provide!!!
Allen
ALLensTRAC
Postby alltrac101 » Fri Apr 11, 2014 3:47 pm
Hey Allen
I'm running 13" x 1" rotors & if I remember correctly the spoke to caliper was at least 3/8" - 1/2" at its closest point....if you run a 14" rotor the spoke moves away from the caliper so there will be even more clearance....I all depends on the hat offset & caliper dimensions of course
Good Luck
Pat
alltrac101
Postby ALLensTRAC » Fri Apr 11, 2014 10:46 pm
alltrac101 wrote:Hey Allen
Good Luck
Pat
Thanks for the quick reply!!! Are your Wilwoods 4 or 6 piston? Do you have the model number by chance? Current hat offset is 43.8 and I can either go with floating 2 piece 14" or solid 13.1" rotors although they are 30mm thick to your 25mm. If I can get your caliper dimensions I can work out the math and compare. Again thank you for the help sir!!! Your car is THE benchmark when it comes to Alltracs bar none!!
Allen
ALLensTRAC
