I have verification that the 2.17 nemesis is able to run the V6, so my engine management is solved. I'm working on getting just the plug and play harness from Weasey so that I'll have minimal wiring changes necessary to make it work with the nemesis. I have a wiring harness and it works with every plug except I need a different TPS (mine is 3 wire, the plug is 4 wire). I need to find the 5VZ and tacoma wiring diagrams so I know how to do the fusebox rewiring.
Mechanically, I have almost all the parts together for the 5VZ to be fully assembled. I have the driveshaft, tranny, clutch, TOB, flywheel's on its way in the mail, all engine sensors, ignition coils, etc. So, it's just about ready to go. I need to get the last of the wiring harness stuff for the nemesis, then I can start assembling. =)
